Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 04-16-2008, 03:26 PM   #1
Gregg S's Avatar
Profile:  2002 25' Safari
quincy , Massachusetts
Hot Water Drain
I just bought an 02 safari and have both gas and electric hot water. They installed the electric coil into the normal drain value area. Now to drain the tank I have to unplug the coil then unscrew it to drain. The gas line runs infront of the plug for the coil and there is no room to work. My question is there any other location to install a drain? All ideas are welcome
Gregg S is offline   Reply With Quote
Old 04-16-2008, 04:52 PM   #2
goransons's Avatar
Profile:  1969 25' Tradewind
Yakima , Washington
if its a suburban then you usually pull the anode rod. It unlike the electric element can be removed without removing the burner tube. The philosophy I gather is that if you don't have to remove the anode rod, most if not all people would likely never check it, but being the only means to drain the tank it comes out at least once a season. Personally I think its a pain in the butt, particularly right now when I'm charging the system to check it out, then using for several short trips spaced apart by a few weeks, longer than I want to leave standing water in the system.
goransons is offline   Reply With Quote
Old 04-17-2008, 03:10 PM   #3
2airishuman's Avatar
Profile:
hi gregg
there is no anode rod on these newer a/s supplied units and
and my understanding is that, it's not needed as the water heater tank is coated.
IF your unit has a electrical element installed IN the original drain plug...
that's an aftermarket, non approved modification....
i'm not a fan of using these accessory heating elements, BUT if using one...
it should be removed regularly for inspection, draining/flushing the tank and
to keep the threads from galvanic/electrolytic sealing...
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 04-17-2008, 03:14 PM   #4
Gregg S's Avatar
I do believe that it is an aftermarket install. Can i put back the stock drain valve and where is the best place to order it
Old 04-17-2008, 03:27 PM   #5
Profile:
the stock plug is synthetic material (nylon i think) black or white...
most rv shops keep then in supply, cw sells them; about 3-5 $ for 2...
and i keep 4-5 extras in the trailer, for friends!
cheers
2air'
Pingbacks are On
Needed, drain plug for hot water tank! wacnstac Fresh Water Systems 8 10-16-2007 08:22 PM
hot water water on demand with a with a normal water heater 62overlander Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Hot water tank drain. FreshAir Water Heaters, Filters & Pumps 1 03-03-2007 07:53 PM
water leak- hot water tank vent glacierrunne Water Heaters, Filters & Pumps 2 05-29-2006 07:14 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
Search Engine Friendly URLs by vBSEO 3.2.0 RC8
