Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 09-09-2006, 09:04 PM   #1
jfowler218
jfowler218's Avatar
Profile:  2004 25' Safari
Oak Park , California
Hot Water
Aside from having a lot of unwanted cold water how do you know when it is time to replace the heating unit (anode?) in a water heater?
jfowler218 is offline   Reply With Quote
Old 09-09-2006, 09:10 PM   #2
dwightdi
Profile:  1977 31' Sovereign
McHenry , Illinois
If your unit is equipped with a sacrafical corrosion protective anode, you should inspect it when you winterize each year and replace it if there has been a lot of corrosion to the anode.
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
Faulty Emerson RV E-330-5 Hot Water Dispenser winner Water Heaters, Filters & Pumps 4 08-02-2002 02:07 PM
hot water heater 53flyingcloud Water Heaters, Filters & Pumps 4 07-08-2002 10:18 AM
Water Pump Dbraw Water Heaters, Filters & Pumps 6 06-15-2002 10:35 AM
Size of black water tank glyoungca Waste Systems, Tanks & Totes 3 06-10-2002 04:17 PM
