Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 06-12-2006, 09:20 AM   #1
Nicksut
Profile:
Hot H2O Burner Cuts Off-Restarts
Hi,
On my 1996 Sovereign my hot water heater burner cuts off sometimes before the water is really hot. Also, it seems to have a hard time starting and I hear it clicking away before it starts up. While in action heating water, before cutting off, it seems to close down and gets real quiet. Then sometimes it goes out and tries to restart (click, click, click), or it will roar back into action and sound normal. Any ideas about what to do? I figure my problem is either with the thermostat or the burner mechanism, but I'm just floundering in the dark here. Thanks in advance for any ideas. Nick
Nicksut is offline   Reply With Quote
Old 06-12-2006, 10:25 AM   #2
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
check the tightness of the mounting screws on the brain box, in particular the one with the ground wire.
might solve your problem, it did for me!
john
you call them ferrets, i call them weasels.
Old 06-12-2006, 10:33 AM   #3
HUGH&NITA
Profile:  2004 25' Safari
Pace , Florida
I'm having the same problem with my Safari. I'll be watching this thread for replies.
HUGH&NITA is offline   Reply With Quote
Old 06-12-2006, 10:52 AM   #4
sander17
sander17's Avatar
Profile:  1996 28' Excella
Okemos , Michigan
Images: 42
Also pull the main electrical connector and clean the contacts. See if you can find some contact cleaner at Radio Shack, or try an emery board for the famale part and gentle action on the strip with fine sand paper. Our 96 was acting flaky and that cured the problem.
Dave
Okemos, MI
T.V.:'05 Dodge Ram 2500 4x4 Quad Cab Cummins
AIR#2276
sander17 is offline   Reply With Quote
Old 06-12-2006, 11:23 AM   #5
Excella CM
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
balky burner
You may well have a bad capacitor on the PC board. You can have a radio shop check it and replace it, if you aren't familiar. You can change out the board, but it costs more.
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 06-12-2006, 11:57 PM   #6
Nicksut
Profile:
[quote=sander17]Also pull the main electrical connector and clean the contacts. [quote]
What is the main electrical connector? The wire going to the sparker? I suspect you mean the wire that powers the whole thermostat and ignition system... hmmmm I guess I can figure out which that is.
Another query: The burner makes a lot of noise, but if I close down the air intake it makes less noise. How do you determine the correct amount of air? I live at 8300 ft, so I would guess I need a wider opening.
Yet another query: Noticed water in the burner pipe. Is this normal? At first I was alarmed, but now that I think about it, I suspect it's condensation.
Thanks for all the advice so far. I'll try everything and hopefully something will work! Cheers, Nick
Help!! Hot Water Heater Flame is Too High emmy Water Heaters, Filters & Pumps 3 03-02-2006 02:29 PM
Hot Water Heater Exhaust Damage Road Ruler Water Heaters, Filters & Pumps 11 11-11-2002 02:27 PM
Faulty Emerson RV E-330-5 Hot Water Dispenser winner Water Heaters, Filters & Pumps 4 08-02-2002 02:07 PM
Yukon AC cuts out towing.... dscluchfc On The Road... 10 07-27-2002 11:01 AM
Looking for ideas hot water FrankR Water Heaters, Filters & Pumps 3 05-09-2002 10:28 AM
