Old 01-02-2015, 03:37 PM   #1
Fort Worth , Texas
Hooked up water in winter and can't get water pump to pump water
i brought out my 2012 FC for New Years. It was winterized.
Hooked up everything I thought but the water pump isn't pumping water. Barely any water comes out when I'm off grid and using fesh water tank. I hear the pump running but am not getting desired results.
I'm new to all of this so what could it be? I relight ended the valves to the water pump with no luck.
mrpettit is offline   Reply With Quote
Old 01-02-2015, 05:58 PM   #2
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Check all fittings to make sure they are tight and not sucking any air. You might need to help along getting it to prime if it 's been sitting awhile. If you get the water flowing it should be good after that. If not you might be in for a new pump or a rebuild if you can get the parts.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 01-02-2015, 06:35 PM   #3
twobikes's Avatar
1997 25' Safari
Montgomery , Alabama
This will sound loony. I couldn't get water out of my faucets after dewinterizing. Sound but no flow. I was about to replace faucet innards ....then I took the aerator off the end of the faucet. That was it --TWICE! Tiny drops of water had expanded in that mechanism and jammed it closed. (now I take off both aerators and spray nozzles during winterizing) if I had pumped pink RV anti-freeze through my system, this would not have been a problem.
Follow us at two bikes + an Airstream. Http://Airgo.blogspot.com
PAT & AL MEYER
TAC AL-26 WBCCI 2626
Montgomery, Alabama
follow the Two Bikes and an Airstream blog at http://airgo.blogspot.com
twobikes is offline   Reply With Quote
Old 01-02-2015, 06:39 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
If my take has been empty I have to totally fill it to get water flowing. After that it works normally. I guess it gets air in the lines and needs the increased water pressure to get it flowing.
MICHAEL
Old 01-03-2015, 12:22 PM   #5
slpiotro's Avatar
2007 23' Safari SE
Madison , Wisconsin
Send a message via ICQ to slpiotro
I just went through the same sort of issues. I was hooked to city water but no flow in bathroom sink. The pump ran but sound was quieter than normal. After three days finally got good flow to sink and pump started working right. Best as I can tell, it was just a lack of water sealing the pump some how. I will worry about it the rest of the trip, but it is hard to ask someone to fix it when it works: :-)
"Honor those who serve by listening to them and caring. Parades end, caring needs to be there every day."
slpiotro is offline   Reply With Quote
Old 01-03-2015, 02:59 PM   #6
Ray Eklund's Avatar
2014 25' International
Boulder City , Nevada
Your water line(s) are frozen.
Winterizing is the time while in outdoor storage that the water lines are blown out, the water pump is drained, the hot, grey, black and fresh water tanks are as empty as possible to prevent damage from freezing. Even worse is freezing with water lines under pressure. You could find yourself in a major plumbing project.
From your description, this is the my diagnosis. The water line to your water pump is frozen. Even an icy mush will clog the filters and block the free passage of water from A to B. Your drains have antifreeze to prevent them from freezing for winterizing. I am told you can drink it, so if it is filling your water lines... flush them as it cannot taste that good.
Are you in Fort Worth or Anchorage? A bit of missing details.
Open the lower cabinets where the water pump and any water lines are. Run the furnace and get air to these areas. If the temperature is anything close to what we are having in Colorado... you are frozen until warm weather arrives.
If in Texas and hit the mid 20's and tomorrow is back into the upper 40's... things will thaw out. I always travel DRY when traveling during the winter months at elevation. We carry a five gallon fresh water container for any cooking needs, dog water, flush the toilet.
Some trailers have systems to heat the fresh water. I have not even checked to see if our 2014 has these options, or if they even do any good.
These are not House Trailers with insulation, hot tape on pipes and have bales of straw around the airspace below the trailer. You are in an Insulated Ice Box with wheels.
Attach the hose to the City Water line and run the water under pressure to your faucets if you are not concerned about water lines freezing up... now or again. If you have NO water... frozen water line. Time will tell, if it warms up.
I could be 100% wrong. That is a double edged sword. Then you have water line and pump problems to be discovered shortly.
I wish you the best, but if you are camped among other trailer owners... they will have the best information for where you are and what to do next!
Ray Eklund is offline   Reply With Quote
Old 01-03-2015, 03:11 PM   #7
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
A couple of things come to mind.
Are the hot and cold water drain valves under the trailer closed?
Take off the faucet screens and see if water flows, they can clog with mineral when not used and things come loose in the lines.
Doug and Cheryl
Old 01-04-2015, 01:04 PM   #8
Fort Worth , Texas
I got it to to work. I filled up the tank 100%, I then hooked up to city water and made sure that worked. The with just the tank again it was flowing ok but not 100% so I tightened the water pump valves even more and it works great.
One more question I may start another thread on - does the propane water heater work better than the electric. I've never used either with the outside temps in the 30s but the water was war but not hot. I had it on electric not propane. Is that a reason it wouldn't be hot?
Old 05-06-2015, 07:46 PM   #9
Looking 4 new adventures
garympeck's Avatar
1996 28' Excella
Apache Junction , Arizona
Here is the latest...city water works on streetside but not on curbside, same for water from holding tank. I have hot water in bathroom sink but no water in kitchen sink or shower. Is there a shut off valve that I haven't located?
Gary ,Linda & Jasper 🐶 Peck, Apache Junction, Arizona
1996 28' Excella, 2015 GMC Sierra 2500HD Duramax
Enjoying our retirement and AirStreaming at least four months a year!
garympeck is offline   Reply With Quote
Can't get water to pump from fresh water tank xbr443 Fresh Water Systems 6 01-20-2015 07:34 PM
water dripping from city water hose attachment location when NOT hooked up to city wa Wilmington Plumbing - Systems & Fixtures 1 03-19-2012 10:25 PM
Can we run ac w/out dc battery hooked up?? lynxranch Electrical - Systems, Generators, Batteries & Solar 6 07-11-2011 10:11 PM
1974 safari water leak when hooked to town water Jasper_pilot 1974 - 1979 Safari 8 06-09-2007 03:18 PM
Can you tell we're hooked? FordTruck On The Road... 10 05-16-2007 07:12 AM
