Old 03-30-2009, 07:42 PM   #1
mouth012006's Avatar
1974 Argosy 24
Science Hill , Kentucky
Images: 51
Help with making a vent?
We have hooked up our tankless hot water heater.....and now we are having to add the venting to the place where it has been installed. What would be the best way to do this.....we placed it in the rear closet of our
Argosy that has a rear bath also....the lines have all been hooked up but now we need to vent this....any ideas would be great.
Kevin & Monique
New to A/S---Not to Honey Do's
Sweetie (lab) Snickers (lab) Blackie(lab)
Dotz(daschund) CB (daschund) Oh and 3 kids!!!
TAC# KY-3
mouth012006 is offline   Reply With Quote
Old 03-30-2009, 09:08 PM   #2
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
many sheet metal shops have the tools to make a louvered panel. You need something like 4"x4"? you might see some examples of this on refer outside access doors.
Zep
Old 03-31-2009, 08:23 AM   #3
1974 Argosy 24
Images: 51
I am not sure how to go about cutting out the section that needs to be done.....the venting will need to be done for the top section of the hot water heater.....
Kevin & Monique
TAC# KY-3
Old 03-31-2009, 09:24 AM   #4
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
You will need something like this. 4" hole saw. I wouldn't make any cuts until the vent was figured out though. You only get one shot at this.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 03-31-2009, 10:37 AM   #5
1975 31' Sovereign
1977 23' Safari
A 4" hole saw is a great tool, just be careful because the torque of a misaligned holesaw can be awesome. Make sure you're putting the hole in an area that doesn't have a stringer or a rib inside. You can tell by the rows of rivets (usually). Also, think about where wiring might be--all circuits come down from the center of the ceiling, so generally speaking if there is no outlet below where you're cutting, you are OK. A hole saw is safer than a saber saw in this respect, if you carefully prevent the saw from diving inside the wall as the disk is cut free.
A saber saw works quite well on Airstream aluminum, but you need to tape the skin liberally to avoid scratches from the foot. Also, the blade, when fully extended, is probably longer than the depth of the shell, so you'll hit the other skin if you don't devise a standoff of some sort, like a piece of 3/4" wood under the foot of the saw.
You might also look for a hand-nibbler at Harbor Freight, which needs a 3/8" hole to start.
BTW, have you thought about providing a combustion air inlet so that the heater doesn't draw cold air in through the door and window seals? The down side is, such an inlet provides another path for outside air infiltration when the heater isn't working.
Zep
Making better use of space jzelle General Interior Topics 7 06-22-2008 01:51 PM
Making sure the power's on Stefrobrts Batteries, Univolts, Converters & Inverters 25 05-18-2008 12:35 AM
Making tire changes SRW Tires 7 03-16-2008 06:35 AM
Loosening Vent Handles and Aluminum Vent Replacement kiincaidjess Roof Vents, Skylights & Fans 4 04-16-2007 11:37 PM
making my own awning....... AnnZ3 Awnings 11 09-03-2004 08:42 AM
