Old 11-11-2013, 04:03 PM   #1
1978 31' Excella 500
Santa Cruz , California
Help! Water leak from fixture on '78 Excella water heater tank
The little outlet that has a cap with a hole in the middle hole pours out water when I turn on the water. See the picture attached. Internal sinks for bathroom and kitchen run fine and no leaks, but gushing water from water heater obviously needs to be stopped... Any idea what i need to do?
TimeLord is offline   Reply With Quote
Old 11-11-2013, 04:24 PM   #2
Coastalview's Avatar
2002 27' Safari
Carmel-by-the-Sea , California
Images: 14
Send a message via AIM to Coastalview Send a message via Yahoo to Coastalview
Hi there, well the good thing you've done is to flush the water heater.
RV NOW: Flushing the water heater is essential RV maintenance
These older units used a metal plug which I'd continue to use like this one;
Camco Drain Valve
or the cheaper plastic one;
https://www.americanrvcompany.com/At...iler-Camper-RV
I don't endorse ether of these vendors, just queried the internet
AIR: 649
TAC: CA-40
Northern California Airstreamers
Coastalview is offline   Reply With Quote
Old 11-11-2013, 04:33 PM   #3
1977 Argosy 24
Milltown , Wisconsin
A threaded plug goes into the hole where the water is coming from. It's the drain for the water heater.
ventport is offline   Reply With Quote
Old 11-11-2013, 05:55 PM   #4
Wow. Feel kinda silly now, but relieved! Thanks!
