Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 11-09-2018, 07:29 PM   #21
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
I can’t explain the pump only aspect, but there is supposed to be an air cushion in the top of the water heater. I can’t remember the exact procedure to restore it, but if you disconnect from city water, turn off the pump, and pull the drain plug on the heater until it empties that should do it. Then replace the plug, hook up to city water and open a hot water faucet until the tank fills and water comes out of the faucet.
The manual for your heater should have the exact procedure.
Al
Old 11-09-2018, 08:25 PM   #22
2007 22' International CCD
That is the exact procedure. Never lift the pressure relief valve lever to fill the tank. Run a hot faucet until it quits spitting air is the correct way to fill the water heater.
Old 11-10-2018, 04:37 AM   #23
Sag Harbor , New York
Ditto x2 ^^^^^^^^^
Old 11-10-2018, 05:15 AM   #24
Adventure.AS's Avatar
2017 25' International
Niagara-on-the-Lake , ON Canada
Using HW Pressure Relief Valve to Restore Air Gap
Al
Here is the procedure in my Atwood Manual for restoring the air gap using the pressure relief valve:
"TO REPLACE THE AIR GAP FOLLOW THESE STEPS:
1. Turn off main water supply (the pump or water hook up source).
2. Let water cool or let run until cool.
3. Open the hot water faucet closest to the water heater.
4. Pull handle of pressure temperature relief valve straight out and
allow water to flow until it stops.
5. Allow pressure temperature relief valve to snap shut; close faucet;
turn on water supply.
6. Turn on water heater and test."
The manual also suggests using the pressure relief valve when draining the tank for winterization.
Ray B.
Adventure.AS is offline   Reply With Quote
Old 11-10-2018, 05:31 AM   #25
The procedure quoted from the manual may result in a smaller air head at the top of the water heater IMO. The steps outlined by Al and Rich are a better method IMO.
Our water heaters are basically the same as residential units, and most plumbers would follow the more complicated procedure, not the AS manual.
BTW it is not necessary to empty the water heater completely, just to get the water level a few inches below the PRV. This means you have to re-install the plug at the bottom as water is still draining out. If it is lukewarm, and you shut the PRV, not a big deal.
Agree to disagree.
Peter
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
Very low water pressure for hot water from pump barrettjl Water Heaters, Filters & Pumps 21 10-27-2014 07:41 AM
Hot hot hot aluminum! 58cruzer General Repair Forum 23 06-24-2013 01:08 AM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
Leak: Fired Up Hot Water, Now There's A Leak SSChanger Fresh Water Systems 4 07-15-2009 08:46 PM
