Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 05-29-2002, 07:12 PM   #1
emmy's Avatar
Profile:
Help!! Hot Water Heater Flame is Too High
Hi there !
I am new to this forum as you can tell by this being my first post. We have a 1970 Sovereign which we love dearly. We have owned it for almost 2 years and have had just a few problems with it. This past weekend I did not have hot water. I assumed that I had run out of propane and told Dh. He got some more and told me that he thought the hot water heater was shutting itself off as the flame was very high and coming outside of the opening where we light it. This is the first time that this has happened. The pipe that has the air adjustment is very rusted and appears to have rusted out by an inch or two short right where the pilot is. My questions are:
1. Could this rusted pipe falling short be causing the high flame?
2. Does this system have automatic cut off ( the warning label is too faded to read)?
3. If the pipe could be the problem is that something we can order or will we need a brand new h2o heater?
4. Any ideas on anything else that could be the problem?
Any and all insight and thoughts and theories would be appreciated as this is our first camper and neither of us are experienced in the "inner workings". If our manual addressed this dh didn't find it.
Thanks in advance as I do miss my hot water!!
emmy
emmy is offline   Reply With Quote
Old 05-31-2002, 07:10 AM   #2
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
If the flame is coming back out of the opening, it would appear to me that the flame tube is clogged with "something" such as spider webs or a mouse nest. Try cleaning that out first. You may be able to get a new gas valve-burner assembly for your heater if it is all rusted out. You could also upgrade to a new heater, if you wanted, cost $300-550 depending on model and options. You will be set for another 20-30 years if you replace the whole thing.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 03-02-2006, 12:34 PM   #3
Profile:  2002 16' Bambi
covington , Louisiana
rookie to forum !!the
tenswade is offline   Reply With Quote
Old 03-02-2006, 02:29 PM   #4
Condoluminum's Avatar
Profile:  1988 25' Excella
Sunnyvale , California
Flames from Rusty Pipes ... Bad!
Emmy-
Without observing yours, I'd say flames visible outside pipes and rusty pipes imply bad situation.. It's possible prior owner adjusted gas flow manually to keep Thermocouple hot and avoid shut-down, or pipe could be clogged, or pipe could be leaking gas and gas leaking is ignited by gas in proper burner zone...
Regardless of detailed cause, that is not good. Water heater often in area where wood cabinetry nearby, and shutoffs are major nuisance... I would seriously consider investing some of the $$ saved by buying used unit 2 years ago (probably $40K compared to a new one..) and having new electronic ignition water heater installed, including the electric heating rod for use with 110V power. A new one will have safe thermostat, overtemp cutoff, pushbutton ignition from indoors, and use less gas. In addition, the tank is likely to outlast yours, and a tank failure is a messy thing...
John McG
Condoluminum
Condoluminum is offline   Reply With Quote
Pingbacks are On
Nobody needs a hot water heater!!! Rick Alston Off Topic Forum 109 02-13-2004 09:52 PM
Lighting Hot Water Heater hhuber Water Heaters, Filters & Pumps 14 04-01-2003 09:31 AM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 07:26 AM
hot water heater bypass tomb 1987 Sovereign 1 11-22-2002 01:04 PM
Hot water Heater DClark Water Heaters, Filters & Pumps 11 08-26-2002 06:04 PM
SEO by vBSEO 3.1.0
