Old 03-12-2014, 08:32 PM   #1
1999 28' Excella
New Orleans , Louisiana
Heating element size?
Think I need a new heating element but what size is in a 6.2 gallon water heater?
Help me if you can!
Thanks, Kat
badkat is offline   Reply With Quote
Old 03-12-2014, 08:43 PM   #2
cameront120's Avatar
1972 25' Tradewind
I suppose it would depend on whether you have a Suburban or Atwood. I suspect you can get the right replacement part by contacting your local RV supply shop as these water heaters are pretty much universal to all brands of RV's.
North Vancouver, BC
Old 03-12-2014, 08:47 PM   #3
1999 28' Excella
It is an Atwood..
Old 03-12-2014, 08:48 PM   #4
1999 28' Excella
It is an electric/gas Atwood 6.2 gallon
Old 03-13-2014, 12:20 PM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
They are, I believe, all the same, 120v, 1400w. Some manufacturers call them 1440w or 1500w -- I doubt if there's a difference.
Old 03-14-2014, 10:08 AM   #6
1999 28' Excella
We have changed the relief valve recently because it failed.right after that the electric side of water heater quit. We then changed the heating element. Duh, still not working. Any suggestions?
Old 03-14-2014, 10:39 AM   #7
1972 25' Tradewind
Is it the original water heater? Might be easier to replace it than spend a lot of time and money on an old unit. It's an easy swap that only takes a couple of hours.
North Vancouver, BC
Aux Heat Element Question Ridgerunner3 Furnaces, Heaters, Fireplaces & Air Conditioning 2 02-12-2012 08:16 PM
1963 Tradewind Original Wheel & Tire size?? BurritoWagon 1959-69 Tradewind 20 02-08-2012 03:27 PM
Heating system ideas? Tinpickle Furnaces, Heaters, Fireplaces & Air Conditioning 4 08-31-2011 03:28 PM
POLL: AC BTUs, Trailer Size, and Climate Shiloh Furnaces, Heaters, Fireplaces & Air Conditioning 19 05-14-2011 11:51 AM
Tires and tire size KyMoonshine Tires 5 03-08-2011 05:28 PM
