Old 02-17-2003, 09:07 AM   #1
Roundhead's Avatar
H2O replacement filter 1971
I'm still in the throes of acquisition of my 1971 Overlander, but expect to take possession next weekend.
At the moment, the stainless steel canister that holds the water filter (under galley sink) is disassembled.
Can someone point me to a good spot to buy the gasket, clamp, and water filter cartridge for this apparatus?
I don't have the old cartridge, so I've got no info to go on.
Thanks.
One other thing: Seller acidentally backed the A/S into a large stump, so there is a large dent in back bumper that interferes with the operation of the hinged access door back there.
Can I remove the bumper, pound it out, and re-install? How will that look? Anyone think I should replace it?
--Matthew
Roundhead is offline   Reply With Quote
Old 02-17-2003, 10:21 AM   #2
Everpure
Matt,
Camping World sells the Everpure replacement cartridge's.
2 for $45-$50 Their order # 19269
Water treatment system order # 4140
www.campingworld.com
John
John is offline   Reply With Quote
Old 02-17-2003, 01:11 PM   #3
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
My units PO didn't winterize last year so the Everpure canister froze and got deformed to the point that it is unusable. So I bought a Culligan RV type filter a Lowes and installed it. It just filters sediment and has a carbon filter for taste. We bring bottled water for drinking and cooking anyway. I don't think I would drink the water out of the fresh tank, even if my trailer was brand spanking new.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 02-17-2003, 01:25 PM   #4
Images: 55
Regarding the bumper, yes you can take it off and pound it out. The PO of my trailer caught the edge of the bumper and bent it out and downward. I took it off (4 bolts) and pounded it out with a rubber mallet. I then took an abrasive wheel and file and smoothed the whole surface. i was going to polish it, but it came out looking so nice as a brushed finish that I left it. It matched the unpolished (but still clearcoated) finish of my trailer much better.
Good Luck
Tripp
Tripp is offline   Reply With Quote
Old 02-17-2003, 02:03 PM   #5
Roundhead's Avatar
Thumbs up
Hey, that's great, Tripp. Thanks.
I'll try the same.
It's a pretty good-sized piece of metal. I'm sure the replacement would not have been cheap.
I will also have re-rivet the lower decorative, blue-colored band. It popped loose when he hit the stump.
Old 02-17-2003, 02:04 PM   #6
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Back Bumper
On my first long trip, in Poteau, OK, an old lady driving a big old car backed out of a parking space and into my bumper. I was about 50 yards away and heard her hit and saw the trailer bounce.
Like Tripp, I removed the bumper and pounded it out using a block of oak and a mallet. On mine, there were 4 Phillips-head screws holding the bumper on. I had to use the largest screwdriver I own with a crescent wrench on the shaft for leverage to get the screws out. I used emery paper and then rubbing compound to smooth the surface.
I do have an area about the size of my hand that doesn't quite match the rest of the bumper, but it doesn't look bad. I see it because I know it is there. No one else has remarked on it.
John W. Irwin
WBCCI #9632
Old 02-17-2003, 02:08 PM   #7
Roundhead's Avatar
Thumbs up
John,
Thanks for more good news on this repair.
I saw the screws, too! Very large!
--Matthew
Old 02-17-2003, 02:42 PM   #8
New Borockton , Alabama
Images: 21
The filter cartridges are out there but not sure if the Camping World 19269 is the correct cartridge for a 1971. Take it out and look for part/model number on the canister and go from there. I think the Everpure 150 was used also.
Here is what you want to avoid getting into your drinking cup! I split this SHURflo a couple of weeks ago because it stopped working. Duh, I wonder why. It is not out of my Airstream but one that I used to transfer water while dry camping. It too will get its own strainer/filter.
Randy
Old 02-17-2003, 03:41 PM   #9
Everpure
Is the Everpure filter just for the single glass faucet?
I drink bottle water, so I don't use it and don't want to waste money on something that I'm not going to use.
John
Old 02-17-2003, 04:25 PM   #10
Images: 21
John,
Yes it is. I have a 94 also and the water out of the small sink faucet is the only faucet that uses the filter. Not sure about the 71 in question though. The filtered water taste the same as bottled water to me.
Randy
FULFLO Replacement water filter AccessMaster Water Heaters, Filters & Pumps 6 09-15-2011 03:31 PM
Tranny 'flush' or Filter change Sav'h Steve Mechanics Corner - Engines, Transmission & More... 18 04-02-2004 08:22 PM
Kohler generator fuel filter ViewRVs Mechanics Corner - Engines, Transmission & More... 3 08-23-2003 06:17 AM
Trip report (fuel filter issues) PeterH-Airstreamer Airstream Motorhome Forums 10 08-01-2003 05:57 AM
Fuel Filter Replacement ViewRVs Mechanics Corner - Engines, Transmission & More... 8 03-06-2003 06:05 AM
