Old 09-26-2003, 07:24 AM   #1
H2o leak from below (hot H2O tank ?)
I plucked a 63 Globetrotter late last yr from an elderly man unable to orient me (I am a mechanical idiot !). When I attatch fresh water supply water pours from underneath . It appears to come from a large pipe exiting the hot h2o tank with a pressure release elbow , the lever hisses a little when I fiddle with it . ( I have not lit tank yet). There seem to be no cutoffs to bypass hot tank . Any ideas on where to begin solving this . Fucets have LOW pressure (most of the water seems to be coming right out of the bottom . Need help desperately .
thanks,
bigwoody is offline   Reply With Quote
Old 09-26-2003, 07:38 AM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Terry,
It sounds like the hot water pop off is jammed in the open position. It may be made to close, or it can just be replaced. It should unthread from the heater. Take it with you to the Hardware store and get an EXACT match. Take it home and reinstall. DO NOT JUST PLUG THE HOLE. This can lead to the water heater building enough pressure to EXPLODE and kill you or any else nearby.
Should be in the 20 dollar range.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 09-27-2003, 01:04 PM   #3
Sounds logical but I can't get it out ! Cap on the T unscrewed but the "guts" of the thing seem hung up inside ?!.
Old 09-27-2003, 06:57 PM   #4
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
The whole thing should thread out of the tank. Could be seized in there from age. I do not know what to reccomend to get it out without further damage. Sorry.
Brett G
Water leak from Holding Tank Drain gwilliam Fresh Water Systems 5 04-18-2010 06:45 PM
Fresh water tank leak Flex Fresh Water Systems 3 09-30-2004 04:25 AM
Front Holding Tank Leak Deejay Fresh Water Systems 0 07-08-2003 07:29 AM
Leak in hot water heater tank Rog0525 Water Heaters, Filters & Pumps 8 06-10-2002 02:10 PM
