Old 10-17-2012, 05:56 AM   #15
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
You may want to put PPL on notice about the poor condition of the unit when you opened the box. Who knows what else could have been damaged when this thing tossed around by the gorilla in the shipping room. (reminds me of the old Samsonite suitcase ads with the gorilla handling luggage).
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 10-17-2012, 07:07 AM   #16
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
That's a good point, will do today.
Silverflames is offline   Reply With Quote
Old 10-17-2012, 11:01 AM   #17
1969 29' Ambassador
PPL is great. They offered to ship out a new one, or put a 45 extenion on their return policy. I will try to get it installed and see how it works.
Old 10-23-2012, 07:22 PM   #18
1969 29' Ambassador
Well I got the door adapter on the main heater. I attached it with SS self tapping screws. Added a layer of sealer around the joint. Then I cut some shims to try to level out the unit. I plan to add sealer around the edges after I got the unit working. Getting the door to line up was a little tricky, but it worked out ok. .
ID:	171214   Click image for larger version
Old 10-23-2012, 07:32 PM   #19
1969 29' Ambassador
The water lines matched up and are in the same place as the old unit. It was a nice fit. Wiring was very simple, 1 power lead to to hook up and two grounds to hook up. I was able to get the power on and the unit running but without the gas.
I was surprised how loud the blower motor is and how much air it puts out. If anyone already has one of these units I would like to hear if your units is loud when the blower motor motor is running.
I found one water leak inside the unit that was corrected by tightening a compression fitting, and a safety switch had to be adjusted coming out of the exhaust pipe. I think most of these issues were caused by the shipping damage. Once I corrected these problems the unit turned on and was attempting to fire up the burner. How adds more pictures of the installed unit at a later time.
Next will be installing the gas line, fun fun fun crawling back under the old girl.
Old 10-31-2012, 02:14 PM   #20
1969 29' Ambassador
Well I got the gas line hooked up and things seem to be working well so far. The new unit appears to require less water flow to turn on. I have a 1.5 gpm faucet in the kitchen, and I can mix in a little cold water. The temp dial on the new unit works good, and gives a wide rage of temp increases.
ID:	171753   Click image for larger version
Old 10-31-2012, 02:23 PM   #21
1969 29' Ambassador
The outside walls of an AS are not dead straight up. I had to shim the heater a bit to get it to set level on the floor. I questioned how important it really is, but I figured better be safe than sorry.
Old 11-04-2012, 08:26 AM   #22
Birdie Momma
NJtoNC's Avatar
1957 26' Overlander
1956 22' Flying Cloud
Rutherford Co. , North Carolina
thanks for this. im strongly considering a girard HW heater. i was hoping you could give me your option. I currently have a macy water heater installed under the sink and vented to the (furnace) exhaust opening. (we have no furnace).
the macy is a POS and didn't work well from day 1. after a freeze it totally busted and needs to be replaced.
I want to vent this girard out the furnace exhaust.
The install instructions are pretty lame -
http://greenrvproducts.com/wp-conten...ER-GSWH-1M.pdf
it looks like the black circular bit in the photo vents outside, judging from the hole in the [Girard water heater] door.
'57 Overlander | '56 Flying Cloud | '51 Spartanette
NJtoNC is offline   Reply With Quote
Old 11-04-2012, 09:41 AM   #23
1969 29' Ambassador
I guess I could be modified, it was not designed to be used that way. Yes the grey tube sticking out is the exhaust pipe. Behind that is a blower that forces the exhaust out. But it also
Pulls in a bunch of air to feed the burner. So would need to make sure you have plenty of air supply. I think the door has about a 3x4 worth of openings on the door. From fooling around with it, if the burner is on with out the blower, the flames come rolling out the bottom of the burner. So you gotta have the air flow.
It will be easer to winterize, but you will still need to blow it out or add anti freeze.
ID:	172018   Click image for larger version
Old 11-04-2012, 11:00 AM   #24
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
I do hope the newer model is less of a problem to regulate in temperature. The earlier models required 50 PSI of water to operate.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 11-04-2012, 06:16 PM   #25
1969 29' Ambassador
It looks like it requires less water flow to turn on. Also with the dial you have a much larger range to adjust the heat.
Old 11-04-2012, 07:18 PM   #26
arktos55343's Avatar
1972 25' Tradewind
Hopkins , Minnesota
Fortunately, my Girard 1M arrived from PPL in good shape (no gorilla delivery). I'm looking forward to installing it in my '72 Trade Wind.
arktos55343 is offline   Reply With Quote
Old 11-12-2012, 09:47 PM   #27
1969 29' Ambassador
I installed the replacement unit, it's amazing, with no shipping damage, it fired right up and ran great. My incoming water temp is about 75 degrees, so it was limiting at full temp, but turned down it ran great. Here is a pic of the burners fired up.
ID:	172664   Click image for larger version
Old 11-12-2012, 10:35 PM   #28
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Thanks for keeping us posted on this. I've seen the updated Girard units for about $550 so I look forward to hearing more about your progress. If it works well, it would be very tempting. You have to go somewhere cold, please, so that we can hear about the full range of incoming water temps.
Tim
timzog is offline   Reply With Quote
