Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 10-23-2016, 10:26 PM   #21
1968 30' Sovereign
New Richmond , Wisconsin
Hi Otra15! Thank you for asking - and - this project has so far turned out successfully. Given the input I received, some of which triggered additional research on-line on my end, we were able to successfully run the 3/8" copper line from the existing valve under the trailer up thru a newly created hole to join up with the new water heater. I ran into a GREAT and extremely knowledgeable salesperson at Menards (he was actually a retired plumber) that helped talk me through some additional questions I had.
So, the gas line is run and has been tested for leaks. Now, I just have to figure out how to connect all the electrical wires coming out of the water heater to the correct power sources inside the trailer!
cheetah1 is offline   Reply With Quote
Old 10-24-2016, 02:10 AM   #22
Sag Harbor , New York
Thanks for the update!
Old 06-25-2017, 02:26 PM   #23
NDM & 12paws's Avatar
2008 19' Safari SE
Ottawa , Ontario
The rubber gasket on my water heater is cracked. Is it safe to use it? We are about to go camping and the AS dealer here is useless. They worked on my water heater in the fall and didn't notice it was cracked.
NDM
NDM & 12paws is offline   Reply With Quote
Old 06-26-2017, 04:39 AM   #24
2000 30' Excella
Toledo , Ohio
Are you talking about the grommet where the copper comes into the heater ?
woodfox45 is offline   Reply With Quote
Old 06-26-2017, 06:59 AM   #25
2008 19' Safari SE
Ottawa , Ontario
Yes, that's it.
NDM
What fitting? Atwood Gas/Elec Water heater rlindberg Water Heaters, Filters & Pumps 3 04-04-2010 07:15 PM
Atwood Gas water heater - 'click then shuts off'???? kevinyyz Water Heaters, Filters & Pumps 3 05-11-2009 10:18 AM
Atwood water heater -- light on, no gas or spark dre00 Water Heaters, Filters & Pumps 4 02-27-2009 09:51 AM
Switch for Atwood Gas/Electric Water Heater tr674 Water Heaters, Filters & Pumps 8 07-20-2008 10:33 PM
