Hi Otra15! Thank you for asking - and - this project has so far turned out successfully. Given the input I received, some of which triggered additional research on-line on my end, we were able to successfully run the 3/8" copper line from the existing valve under the trailer up thru a newly created hole to join up with the new water heater. I ran into a GREAT and extremely knowledgeable salesperson at Menards (he was actually a retired plumber) that helped talk me through some additional questions I had.
So, the gas line is run and has been tested for leaks. Now, I just have to figure out how to connect all the electrical wires coming out of the water heater to the correct power sources inside the trailer!
