Old 12-22-2002, 11:07 AM   #1
can someonre explain how the electric-propane ones work ?
I understand one or the other but having both would just seem like 2 heaters sitting next to each other maybe using a common tank.....
I assume it will work with only 110v or only propane (how does the pilot light then)
thanks for the info
oldvws is offline   Reply With Quote
Old 12-22-2002, 11:29 AM   #2
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
oldvws
I assume your question has to do with a water heater with a tank.
The electric/propane water heaters are just a conventional propane water heater with an added electric element. The electric element has its own thermostat.
You can convert a plain propane water heater with any of several kits on the market, though I have heard that the manufacturers may void your water heater warrenty. The conversion is simply a 120v heating element replacing the drain plug.
You can run propane, electric, or both at the same time for faster recovery. It doesn't really matter since the thermostats will cut off the sources of heat when the water gets hot enough.
John W. Irwin
WBCCI #9632
Old 12-22-2002, 11:34 AM   #3
Vagabond
TheBigRedTruck's Avatar
1973 31' Sovereign
Fort Meade Md. RV park slot 8!! , Motorsports Photographer
Images: 36
Send a message via AIM to TheBigRedTruck
Works like a standard propane hot water heater with an adjustable thermostat. Some have standing pilots, some have electronic ignition. In the rear of the holding tank there is a 110 electric rod, most are set at a present temp. You can use either one alone, propane or electric, or you can use both for faster recovery time.
Never has so few. Done so much, With so little, That now we can do anything, With absolutly NOTHING!!!! AIR# 300
TheBigRedTruck is offline   Reply With Quote
Old 12-22-2002, 11:34 AM   #4
Pahaska's Avatar
Hays County , Texas
The 120v element works just like the one in your home: a thermostat turns it on and off depending on water temperature.
There will be a switch somewhere in the RV to enable or disable the eletric element. It pulls a lot of current and you want it off when you are using other heavy loads such as electric heaters
John W. Irwin
WBCCI #9632
Old 11-01-2011, 02:09 PM   #5
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Is mine working correctly?
This looked like as good place as any to post this question.
When I have both the electric and gas turned on on our water heater, the gas still cycles on and off periodically even with very little hot water use.
I am wonder if this is normal. Should I be looking at the electric portion to be sure it is even working?
Ken
Old 11-01-2011, 02:12 PM   #6
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
Your electric is most likely working fine, just with a slightly lower thermostat setting than the gas side of things. If the intent is to save propane, I would suggest either turning down the gas thermostat setting, or turning up the electric one.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 11-01-2011, 03:04 PM   #7
lewster's Avatar
Naples, FL , Hood River, OR
The thermostats in the newer Atwood water heaters that are found in newer Airstreams are not adjustable. Rather, they do come in two flavors; 130*F and 140*F. the temp grade should be stamped on the outside edge of the t/stat.
servicing gas part of refrigerator nickcrowhurst Refrigerators 3 02-21-2006 07:46 AM
Electric or Gas electric fridge replacement?? tin can luv Refrigerators 26 03-22-2004 09:50 AM
Open Flame Propane Heater Gas Monitor Results Pick Off Topic Forum 8 01-10-2004 09:25 PM
gas line to water heater bken Water Heaters, Filters & Pumps 0 05-03-2003 08:11 PM
It take 5 minutes to get the gas flowing to my fridge, water heater, etc. TBKP's Overlander LP Gas, Piping, Tanks & Regulators 8 04-15-2003 10:00 PM
