Old 05-04-2016, 06:42 PM   #1
2001 30' Excella
Full-time traveling , Hmmmm. what day of the week is it?
Furnace won't stay lit
Anyone else have this problem?
In our 2001 30' Excella, as of two days ago, the furnace won't stay lit in the morning. It tries to lite 3 times, each time staying lit about 10 seconds, then goes out and 15 seconds later it tries again.
During the day when we don't need it, it stays lit.
Any ideas?
2001 Excella 30' (Beauty)
2014 Ram 2500 Diesel 4x4 (The Beast)
http://www.LivingInBeauty.net
JBBeaubeaux is offline   Reply With Quote
Old 05-04-2016, 08:02 PM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
Look into the exhaust pipe of the furnace to see if there are wasp nest, dirt dauber, or spider webs. If the exhaust is blocked the furnace will not run.
OR
Inside the furnace there is a switch (called a sail switch) that will not allow the furnace to ignite if there is a blockage in the duct. The way it works; the fan blows against the sail part of the switch which moves the electric contacts into the correct position. If lint, hair, or any trash that gets into the ducts builds up on this switch or is preventing air flow it will not allow the furnace to ignite.
OR
circuit boards in the furnace go bad, sometimes they need replacing (I had to replace one in my Safari not long ago, because I was having the same issues you describe)
add edit:
I learned enough by reading on this forum and looking at u-tube videos that I was able to remove and clean the sail switch and replace the circuit board on my furnace.
Atwood HW pilot light won't stay lit LI Pets Water Heaters, Filters & Pumps 9 12-30-2007 04:42 PM
Pilot light won't stay lit abridges01 Refrigerators 5 09-25-2006 12:01 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 05:24 PM
Pilot Light won't stay lit Mike Callaha Water Heaters, Filters & Pumps 15 03-26-2005 01:56 PM
Furnace won't light /stay lit Don Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-29-2002 04:37 AM
