04-19-2012, 08:38 PM
1976 Argosy 26
Lake Wales
Fresh Water Pump
The plastic part where the hose attaches is broken. Does this mean I have to purchase a whole new pump? I have tried PVC Glue to no avail.
04-19-2012, 08:40 PM
Oswego
What make and model of pump? Most have head repair kits which can include the housing. I assume the broken piece is the housing.
-Rich-
04-19-2012, 08:44 PM
2003 22' International CCD
Kiln
, Mississippi
Is the part threaded in - then take it to Home Depot and by a new fitting. If it's part of the pump body the manufacturer will have a replacement part. If as old as the Argosy model you have then there are replacement pumps that are much better.
Michael & Tina with Layla and Preston BZ The family has grown. 2003 22' INTERNATIONAL CCD
04-19-2012, 10:39 PM
1974 Argosy 26
Morrill
, Nebraska
Can you post some pics of the problem?
04-19-2012, 11:41 PM
Denton
, North Carolina
water pumps
If your talking about the clear plastic part that has a screen in it then it is a small cost to replace.
If you are talking about the black plastic head that is part of the pump, I would not spend the time on a repair. When I was working in a service department I had access to all the OEM repair parts and tried many times to repair water pumps. In over the 10 times I tried, I got one to work and it did not pull water like it was suppose to. If your pump has any age on it, and you do replace it, you may be very happy with the improved performance. It is an easy job to replace.
Dan Brown Denton NC
04-27-2012, 10:59 AM
1976 Argosy 26
Lake Wales
I guess I will just replace the whole pump. I just hate being the victum of planned obsolesence again.
04-27-2012, 11:20 AM
Mantua
, Ohio
If I figure right , the pump is over 35 yrs old, things wear out. Am I wrong? jim
04-27-2012, 12:00 PM
1978 28' Ambassador
Morada
If you can swing it, check out the newer variable-speed type RV water pumps...There are several models out there...Here's the one we used to update our AS....
http://www.amazon.com/Flojet-4-5-Wat.../dp/B000LY4EDE
This type of pump will pump only at the speed required - with one faucet open it pumps slowly, but if another faucet is opened, the pump speeds up to keep pace and give necessary flow to both...
Ray & Pat; Morada, CA
04-27-2012, 12:13 PM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
new pump about 70 bucks from Outdoors mart and others. Well worth it. Not sure what plastic part it is, but I went for the new pump.
04-27-2012, 02:12 PM
Moderator Emeritus
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna
Fresh Water Pump
Greetings susans69!
If your pump is the original PAR (Peters and Russell), you have one of the best pumps on the market (IMHO), and it is rebuildable such that it will last for many years into the future. I carry one of the limited-life modern pumps in my parts box just in case either of my PAR pumps experience a failure and I either don't have the part that it need or the time to repair it while on the road. You likely won't find PAR pump parts at an RV parts outlet . . . they have never been commononly utilized in the industry (other than by Airstream and Avion for a time). A marine or boating store with a good parts department will likely either stock the replacement parts or be able to get them in very short order (my loacl pontoon boat dealer gets PAR pump parts for me). If it is a par, the outlet or inlet fitting should be easy to replace.
Good luck with your investigation!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
05-02-2012, 01:26 PM
1976 Argosy 26
Lake Wales
Thank you all. I have repaired the pump and plan to order parts for the future.
05-02-2012, 01:28 PM
1976 Argosy 26
Lake Wales
Yes, it is a par and I have repaired it...thx for all the info
