Old 02-12-2008, 08:14 PM   #1
holland , Michigan
fresh water pump
Today a new issue with the 12v pump and and it would not work after a fill of the tank, drove some 300 miles and worked only sometimes. Checked fuse and ik. checked it tonight and it is working. Could a sensor be bad or air in the lines make the pump not work sometimes? I have lost faith in it for the first time?
safari 28 is offline   Reply With Quote
Old 02-12-2008, 08:27 PM   #2
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Could be the pressure switch
It might be the pressure switch on the pump. Try by-passing the switch by turning the power off and connecting power straight to the pump and see if the pump works first time, every time when you turn the power on. If so, replace the switch.
Old 02-12-2008, 09:20 PM   #3
_
Originally Posted by safari 28
... it would not work...
define 'not work'
1. no noise, not even a hum
2. hums, but no pump noise
3. pump noise, but no water pressure
4. noises never heard before and a green glow from the housing ***
or other options...
those who know will need more info to give ya good dope.
cheers
2air'
*** if the pump is run for long with an empty tank, it will heat up and a safety relay? shuts it down for awhile...
perhaps THIS is what u experienced?
btw i'm on my 3rd oem pump and long past any faith in this little gadget...
Old 02-13-2008, 06:15 AM   #4
lewster's Avatar
Naples, FL , Hood River, OR
'28,
Unfortunately, Airstream does not use the finest quality when it comes to water pumps. Remove it from your trailer, connect a hose from a bucket of water to the inlet, add a 12VDC source and test the pump. If it doesn't work (which it probably won't), I would suggest a Shurflo Extreme Sensor 4.0 pump. 3 year warranty, excellent operation, smooth, quiet and more flow that the OEM model.
Old 02-14-2008, 08:42 AM   #5
holland , Michigan
Works and does not work, only when I need it. Suspect pressure switch and will replace with pump you rcmd lewster/ thanks.
New water pump-? fresh water tank adonh Water Heaters, Filters & Pumps 24 06-19-2008 07:00 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
Fresh water air pump conversion LHall Fresh Water Systems 3 08-28-2007 12:11 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
Fresh Water Tank to Grey + Shower Pump? foshejh Fresh Water Systems 7 12-08-2005 09:22 AM
