SHURflo is a very common water pump. I would suggest installing a SHURflo Accumulator after the pump to reduce the number of cycles the pump goes through when drawing water.
As for pluming fittings consider Sea Tec fittings for any place you may want to remove in the future, water heater, pump, and tanks. They are a bit expensive but great to work with and easy to reopen for service.
2004 Excursion 4x4
