Old 04-06-2014, 10:06 AM   #1
1998 19' Bambi
Mirror Lake , New Hampshire
Faulty pressure relief valve
We have a 97 Bambi with a model G6A-8E Atwood electric ignition water heater. After about 10 minutes of heating water discharges from the pressure relief valve. Cannot find a high temp limit switch so do I just change the pressure valve?
Sawyerpoint
sawyerpoint is offline   Reply With Quote
Old 04-06-2014, 11:07 AM   #2
Sawyerpoint
Yes.
Old 04-06-2014, 11:11 AM   #3
dznf0g's Avatar
Oswego , Illinois
Does it just drip, or blow off a lot of pressure? They are prone to getting deposits on the seal seat and dripping a bit, especially under pressure when hot. If it's just leaking a little, stand back to the side and pop it open and closed a few times. Works most of the time to clean the seat off.
-Rich-
Old 04-06-2014, 11:39 AM   #4
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
This is probably because of the expansion of the heating water in the system releasing pressure through the valve. The system is designed to have an "air bubble" in the top of the water heater to take this expansion, the the air can be lost.
Here's a WBCCI magazine article about it from Airstream, and how to restore the air bubble. Easy.
http://wbcci.org/general-information...-february-2013
Doug and Cheryl
Faulty Floor or Faulty Design? randf Repairing/Replacing Floor &/or Frame 22 05-11-2011 05:38 PM
pressure relief valve twiggy137 Plumbing - Systems & Fixtures 10 05-13-2008 09:20 AM
Pressure relief valve CBsquidSS Fresh Water Systems 4 03-03-2008 03:43 PM
water heater pressure relief valve wayne.yl Water Heaters, Filters & Pumps 12 04-21-2007 06:54 AM
Bowen Pressure relief valve melprice Water Heaters, Filters & Pumps 5 06-16-2002 07:47 AM
