Old 04-18-2010, 09:11 AM   #1
Okiegent's Avatar
1983 31' Excella
Choctaw , Oklahoma
Images: 14
Everpure Cartridge Head
I have a model QC2-AC water filter. I changed the cartridge out and it dripped water slightly. I am wondering if it might have a o-ring or gasket in the housing. I looked in mine and could not find anything. I f someone could shed some light on how they assemble and if there is a o-ring or gasket, I would surely appreciate it. This is in a 1983 excella.
Tom C.
Okiegent is offline   Reply With Quote
Old 04-18-2010, 12:44 PM   #2
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Tom, I have one too and suspect you're not missing anything. The thing is a bear to get on correctly, but once on it won't leak.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 04-18-2010, 02:09 PM   #3
Okiegent's Avatar
1983 31' Excella
Choctaw , Oklahoma
Images: 14
Thanks Pat. It got my dandruff up so badly that I took the darn thing off the mount and put it in my hands so I cold see exactly how it went on. This thing is mounted up under the sink. Very hard to get to.Mine tells you to push the filter up into the filter head then turn to the right until it stops. Then follow up by tightening the ring to the right around the filter. Trouble I got I think is the lug want go on the filter no matter how hard I push and turn. It seems like a simple task. However it is not that easy.
Tom C.
Old 04-18-2010, 04:42 PM   #4
2010 27' FB Classic
N/A , Texas
Sometimes the filter is not seated the whole way in the holder, then it makes turning the ring difficult. If that is the problem, I suggest using a very little vasoline or some water on the rubber "o" ring that is on the neck of the cartridge and it might seat into the holder completely.
Old 04-18-2010, 06:03 PM   #5
Okiegent's Avatar
1983 31' Excella
Choctaw , Oklahoma
Images: 14
Good Ideal Bluto I will give that a try. I got the galley faucet apart ,the water pump and the rear drains down for repairs. You know when you start to fix a leak ,oh well you know. This filter is more trouble than I wanted though.
Tom C.
Old 04-18-2010, 07:23 PM   #6
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
The lube on the O ring is a good idea but, plumbers silicone lube instead of petroleum based vasoline on any form of rubber gasket/O ring/washer.
Old 04-18-2010, 09:36 PM   #7
2010 27' FB Classic
N/A , Texas
Glad to help!
Everpure question mustang Fresh Water Systems 9 04-08-2013 12:07 PM
Removing Bathroom Faucet Cartridge mbmbstreamer Fresh Water Systems 0 05-22-2009 09:29 AM
Gasket needed for Everpure EN-1 Silverwanabe Water Heaters, Filters & Pumps 1 02-15-2008 09:09 PM
Everpure Cartridge and Winterizing Mrs_RedSHED Fresh Water Systems 9 11-05-2007 04:25 PM
Everpure EN-1 Water Purifier TheBigRedTruck Water Heaters, Filters & Pumps 2 06-06-2002 07:36 AM
