Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 01-27-2007, 02:25 PM   #1
kontiki
kontiki's Avatar
Profile:  1989 25' Excella
San Andreas , California
erratic Water pump
I have a 77 Argosy. The water pump seems to come on and off when there is no demand for water. I have checked for leaks and can find none. The pump is an Shurflo model 2088-403-444 and has a mfg date of 12/98. Is there a check valve in the system or are there any adjustments on the pump? Appreciate any and all suggestions.
kontiki is offline   Reply With Quote
Old 01-27-2007, 03:10 PM   #2
commander31
commander31's Avatar
Profile:  1969 23' Safari
Grosse Ile , Michigan
Here's a thought.....
Hmmm..not exactly sure about what a "Shur-Flo" looks like....I have the older style "PAR-Jabsco" dual reservoir water pump on my 69 Airstream.
I know they usually always have a "pressure switch" that kicks the pump on demand when pressure drops...e.g. when you open the spigot.
Thes pumps will cycle anywhere from every few seconds, to every ten minutes, if there is some kind of a compromise in the seal in the water system. Basically, i would start at the pump, and water tank, and trace back every single inch of pipe, all the way to the back of the trailer, esp around the city water regulator, and the hot water heater.
If you have even the tiniest leak in the system somewhere, it will cause a pressure drop enough to kick on the water pump momentarily.
Grab you a flashlight, some patience, and a tall coolie and start to tracing.... My money says you gotta miniscule leak somewhere behind a cabinet, or in the back of the trailer.
Keep us informed on the progress....(or the lack thereof.... )
Scott Anderson
Grosse Ile, MI
Scott Anderson
Grosse Ile, Mich.
1969 23' Safari Twin
WBCCI # 22426
(formerly #22425 1968-76)
When it is my time, I want to go peacefully,
And in my sleep.....Just like my Grandfather....
Not screaming, kicking and in a state of panic,
like the other passengers in his car were......
commander31 is offline   Reply With Quote
Old 01-27-2007, 03:25 PM   #3
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
This message will self-destruct
Disconnect the line from the water pump, and cap the water pump. Turn the power on to the water pump.
If it cycles on & off many times after the initial surge, the problem is with the water pump.
If it does not, there is a leak downstream. Your mission, should you decide to accept it, is to find the leak. Good luck, Jim, and remember if you or anyone on ...
Tom
Old 01-27-2007, 05:35 PM   #4
Chuck
Sad Moderator
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
there's a check-valve in the line near the city water inlet that can wear out...slowly. I first noticed on mine, a small drip coming from the city water inlet when the pump was on...the pump would cycle every few minutes. Since the check valve is really hard to access, I just tried to get by with a 5/8ths threaded plug in the inlet. that kind of works, but it doesn't really make a good seal. as the valve continued to deteriorate, the problem got worse...I finally decided that I had to get a replacement and just "deal" with figuring out a way to access the faulty valve. bought a replacement...still was unable to access the valve, so I just took off the inlet, and screwed the valve in there. so it sticks out a little farther than original....but it works like a charm, and I haven't heard the pump cycle on when it shouldn't since. see my photo gallery for pictures.
only minor issue is that I had to remove it to winterize, as it does trap a little bit of water in the pipe.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 01-27-2007, 09:09 PM   #5
Thealt
Profile:  1967 22' Safari
If you cannot easily find a leak you can see if the water level is dropping in the tank. Just mark the current level with some masking tape and wait a little while to see if the level drops
I have a shurflo in my 67 safari. The installation instructions say that 'restrictions in a plumbing system may cause the pump to rapid cycle during low flow demands... if the pump is cycling you can increase the flow rate. See the manual for the complete steps.
Alt
Thealt is offline   Reply With Quote
Old 05-08-2007, 01:18 AM   #6
davida
Gambierite
davida's Avatar
Profile:  1979 31' Sovereign
vancouver , BC
How do you see water level?
Thealt: where do you "see" the water level in the tank? Do you have an analog tank level meter that works? Our 79 Sovereign has a quaint 5-led setup, but it always reads empty. =(
davida is offline   Reply With Quote
Old 05-08-2007, 03:51 AM   #7
overlander63
Rivet Masher
overlander63's Avatar
Profile:  L.A., Dammit , California
Most '70's vintage Argosy trailers, and mid 60's vintage Airstreams, had above floor plastic water tanks that you could see the water level through. Yours has the tank under the floor, so you would not be able to use this advice.
pump not working... Chuck Water Heaters, Filters & Pumps 23 05-16-2007 10:44 AM
Water Leak jcanavera Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 06-03-2005 09:28 AM
travelling w/out water system maznblu Fresh Water Systems 6 09-09-2002 01:03 PM
Water Drip uwe Fresh Water Systems 6 07-11-2002 09:39 AM
Flushing Black Water Tank 1985air345 General Motorhome Topics 3 05-16-2002 03:59 PM
