01-15-2018, 10:37 PM
S/O#080
2006 30' Classic S/O
Naples
Emptying fresh water tank
I wanted to drain my fresh water tank, and after locating the drain valve it would not drain by gravity but only when pump was on. Is this the procedure or am I doing something wrong? Thanks. Carolyn
01-15-2018, 11:22 PM
Salem
, Oregon
Hi, please give us more information about what you are asking about, what make, model, and size trailer / motorhome that you have. The water pump is not for draining.
I have a 2005 Airstream Safari 25-B travel trailer. My fresh water drain is located between the wheels on the curb side of my trailer. It has a plastic valve with a lever on the top. When I turn this valve towards the front of my trailer the water starts to drain. With a full tank of water, it might take several hours to drain completely. This is normal.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
01-16-2018, 05:17 AM
Chelsea
, Maine
I’m thinking you found the low point drain. Actually there should be two of them, hot and cold. They will gush when the pump is on, trickle and stop with the pump off.
My fresh tank drain is between the wheels on the left side. Handle forward is closed, rearward is open. There’s a little splash plate under it to keep the water from digging a hole in the ground.
My low point drains are just forward of that, tucked in behind the left front wheel.
2023 Entegra Odyssey 26M
2017 FC 27FB
2017 F250 Lariat Crew Cab 6.2L
Equal-I-Zer 10K/1000
01-16-2018, 06:21 AM
1966 20' Globetrotter
johnsoncity
, Tennessee
Replacing drain valve
Has anyone replaced the fresh water tank drain valve. If so what was involved
01-16-2018, 06:49 AM
2005 30' Safari
Montgomery
Just replaced mine. Had it done at my local shop for about $100 when I had it in trying to find some stubborn leaks. It’s a 1/4 turn valve similar to the one you see behind a toilet. Drain faces rearward and the little deflector shroud is still there. I wasn’t wild about limited access to the connection and wasn’t interested in dropping the tank, so money well spent for me.
The original plastic one was trash—and was 12 years old. I’d take a picture but it’s icy out today. We couldn’t use the tank before the new valve, so a serious sterilization of the tank, then the rest of the system, was done according to the info in the AS Guide book. Having a trailer with a functioning fresh water tank rocks!!!
01-16-2018, 09:13 AM
WBCCI 23945 "Blue Moon"
1993 29' Excella
Hillsboro
Just a thought, but I found taking the cap off the fill port, releaved vacuum pressure on the tank.
01-16-2018, 09:42 AM
2009 25' FB Flying Cloud
1973 31' Sovereign
Mt Angel
, Oregon
Yes. My valve was almost impossible to operate so I removed it to see what was up. Nothing was up, but since valve relies on a friction fit in tank to seal, I had possibly created a leak that would require dropping the tank shroud to repair.
Whew, dodged that self inflicted bullet. Valve is still difficult to operate, barely operable by hand, so I use a small crescent wrench.
On my trailer the valve is between roadside tires. Takes quite a while to drain if tank is full to begin with--half hour plus.
Best, Burnside
"To err is human, to air is devine."
01-16-2018, 09:52 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Not a new problem.1/4" ball valve from ACE.
Flange from ebay
Ck his eBay store, handy Honda stuff.
"You don't know where you've been until you leave, enjoy life" RLC
01-16-2018, 10:00 AM
1976 31' Excella 500
Chappell Hill
Where would the fresh water tank drain valve be on a ‘76 CB 31’ Land Yacht Excella 500?
01-16-2018, 10:08 AM
1975 31' Sovereign
West Liberty
, Kentucky
On my 1975 Sovereign the fresh water drain is under the kitchen cabinet (sink). Be sure to open a faucet or 2 or a vacuum will form in the tank which will slow the drainage.
01-16-2018, 10:22 AM
2008 19' Bambi
2012 23' Flying Cloud
2016 25' Flying Cloud
Bandera
On our prior 2008 Bambi, the fresh drain is forward under the roadside dinette seat. Drains with or without the pump, but faster with the pump. On our 2012 23D, the fresh drain valve is on the side of the tank, roadside, between the wheels. Drains like molasses.....about 5-6 hours to drain 30 gallons. Pic shows draining in progress. The other valve is the low point water drain for roadside lines.
01-16-2018, 10:46 AM
2005 31' Classic
Venice
To Robert Cross....does the flange back side (not shown) connect to pex at both ends ?
01-16-2018, 01:29 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Our '03 did not have PEX, it connected to a clear plastic hose with two worm band clamps, (changed to an all Stainless clamp), same as the OEM plastic.
01-16-2018, 01:44 PM
2018 19' Flying Cloud
Newport
You might want to update your profile so folks know what model/year etc. of unit you are talking about. In the case of my 2018 FC19 there are two fresh water tank drains located within less than a foot from each other under the dinette seat. One drains by gravity and the other only with the pump.
Did you receive a manual with your RV? If not you might be able to download a pdf version,
Dale & Jane
2018 Flying Cloud 19
2003 Dodge Ram 2500 Quad Cab Diesel
01-16-2018, 02:08 PM
2010 30' Flying Cloud
Lynchburg
, Virginia
Carolyn,
I just open the gray water drain valve, then open a cold water faucet and turn on the water pump until the tank is empty. This takes only a few minutes and rinses the gray water tank at the same time. You can also use the outdoor shower faucet for the same purpose. Russ
01-17-2018, 08:25 AM
York
, Pennsylvania
While we're on the subject...
Can anyone explain exactly what the low point drains drain, and how they work? I'm not sure how those drains would fit into a plumbing diagram. When I winterized, I did allow antifreeze to flush into those drains ... I think.
01-17-2018, 09:04 AM
1974 Argosy 26
Morrill
, Nebraska
IMHO They are not necessary.
Low point drains don't do much. Other than become another source for a leak.
Unless they are located in the actual "low point" of the plumbing system they don't drain much.
If you are in a situation where the coach is parked on a hill where the drains are actually up hill from the low point. They don't drain much.
In most cases they are located in spaces with poor access.
I live in an area where winterizing is a must. Temps to -40F. Which requires the pink stuff or at least blowing out the system with air. I prefer the pink stuff approach.
If I have a problem with an existing low point drain, ie leaking etc. It gets removed and replaced with a piece of PEX. If it doesn't exist it can't be a problem.
01-17-2018, 01:30 PM
2022 22' Bambi
Villa Park
, Alabama
Seems like in most cases a slow drain is desirable. No need for gushing water make a flood or eroding a hole in the ground. Slow drain gives the nice clean water a chance to just soak into the ground...says the guy who parks on the gravel next to his driveway.
01-17-2018, 06:18 PM
1986 25' Sovereign
Huntsville
, Alabama
Burnside Bob, I've replaced mine and now keep silicon sprayed on it to keep it free and easier to operate.
