Old 04-24-2015, 10:45 AM   #1
1971 27' Overlander
morris , Illinois
electric water heater replacement
I am restoring a 71 overlander. It has no hot water heater in it. Per the manual for its year and size, a 27 footer, it had a 10 gallon Bowen lp in it orginally. I want to replace it with an all electric one. I have removed all lp from the trailer,. I want to run all electric as efficiently as possible. I also want it to be 10 gallon. Can anyone recommend the right heater to get to replace with out a lot of revamping of trailer. Is there one like a suburban or Atwood that will fit in that hole without reconstruction an not using the gas. Press help. I am lost here.
455rocket is offline   Reply With Quote
Old 04-24-2015, 10:59 AM   #2
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Do you intend to use this travel trailer as a park model?
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 04-24-2015, 01:58 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
Either the suburban or Atwood dual fuel (electric/proapane) will work with the gas disconnected. You can check the dimensions and see what will fit.
Old 04-28-2015, 04:59 AM   #4
1971 27' Overlander
morris , Illinois
As a trave trailer
Old 04-28-2015, 05:08 AM   #5
1971 27' Overlander
morris , Illinois
I am being told by vintage trailer supply that I can use the gas heater and add a hot shot kit to it. This is what I plan to do. Can anyone tell me if the 10 gallon one will fit the 71 overlander 27 foot long trailer. Per the manual it originally had a 10 gallon Bowen model in it. Dont want to order until I am sure it fits.
Old 04-28-2015, 05:47 AM   #6
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Measurements are posted online. Check the area you want to put it and make sure it will fit.
BambiTex is offline   Reply With Quote
Old 07-20-2015, 10:03 AM   #7
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Cheapest solution is a small conventional electric water heater:
http://www.amazon.com/Reliance-SOMS-...e+water+heater
Inexpensive and no venting required.
