Old 05-18-2005, 09:00 AM   #1
rfield54's Avatar
2002 19' Bambi
1989 29' Excella
1980 28' International
Avon , Colorado
Images: 106
Send a message via AIM to rfield54
Thumbs up Electric water heater element: Draining dilema
Has anyone found a solution to the difficulty of draining a water heater which has an electric heating element installed? The PO installed the electric water heater, so I just discovered the dilema last fall. I had to disassemble what I'm guessing is the igniter to make even the smallest amount of room. I wonder about the feasability of a seperate port for the element. My handyman skills are "modest", so be easy on me.
Here's a picture:
AIR #2753
www.roybloomfield.com
rfield54 is offline   Reply With Quote
Old 05-18-2005, 09:09 AM   #2
I looks like the previous owner did a good job on shrink-tubing the wires to the Hott Rod element.
What I did was to use heat-shrinkable bullet connectors on my conductors. It makes it easier to unplug the element so I can unscrew it without all of the wiring getting in the way. It works great.
Anon is offline   Reply With Quote
Old 05-18-2005, 09:23 PM   #3
rfield54's Avatar
2002 19' Bambi
1989 29' Excella
Avon , Colorado
Images: 106
I'm not sure I follow you. I assumed all the wires and equipment, with the exception of the electric element (black cord), are stock from the factory.
AIR #2753
Old 05-19-2005, 10:20 AM   #4
They are, but I have modified mine so that I can easily unplug it to remove the heating element to drain the tank.
I am sure that I have voided any and all warranties by doing that but it still works and I can undo is all without have to mess around with it.
I am not sure if the new Hott Rods allow you to unplug it from the base of the heating element but mine is a number of years old. I had heard that there is some company out there making an element that allows you to unplug the wiring right at the base of the heating element.
Old 05-19-2005, 10:07 PM   #5
rfield54's Avatar
2002 19' Bambi
1989 29' Excella
Avon , Colorado
Images: 106
Could you possibly explain your modification? Any pictures would sure be helpful. Thanks, Roy
AIR #2753
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 05:03 AM
Water Heater shell frame BobbyW Water Heaters, Filters & Pumps 0 04-29-2002 10:21 AM
Water heater work tool FrankR Water Heaters, Filters & Pumps 1 04-09-2002 10:57 AM
