Old 08-10-2014, 12:03 PM   #1
1983 34' Limited
Brenham , Texas
Electric tankless for 1983 Limited
Hi: We are planning to remove the old dead gas water heater and replace with an electric tankless model. We are very new at this and would appreciate any advice from someone who has done this before or has any expertise in this department.
Zamelia Earhart
zamelia is offline   Reply With Quote
Old 08-10-2014, 01:01 PM   #2
1974 Argosy 20
Kooskia , Idaho
There is not enough electrical capacity in the 30 amp, 120 volt setup you have in your trailer to use a tankless electric water heater. You could use a small tank electric water heater, say about 5 or 6 gal like the original gas one, but not a tankless one.
Old 08-10-2014, 01:11 PM   #3
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Why? Like idroba said the electrical capacity is not even close to being enough to operate a tankless water heater. A tankless electric wh in a home is even marginal with 240 volts and a 200 amp panel box.
Your best and most economical solution is to replace the original 6 gallon gas water heater with a propane/electric 6 gallon water heater that you can operate on either propane or electric.
Dan
Help choosing an all electric tankless hot water heater Projecttinca Plumbing - Systems & Fixtures 3 03-25-2013 08:35 PM
new gas/electric water heater 1983 31' Ltd paulmsawler Water Heaters, Filters & Pumps 1 03-21-2013 08:54 PM
1983 Airstream 34' Travel Trailer Limited Wally Byam eBay Watch Airstreams on eBay 0 03-12-2009 05:20 AM
1983 34 footr limited bstjames Trailer Values 3 03-10-2008 11:02 AM
What do you know about the 1983 31' Limited? Aluminumb Buyer Guidelines 7 09-15-2007 10:49 PM
