Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 06-24-2009, 04:05 PM   #1
Obsessed with Moonunit
COArgosy78's Avatar
Profile:  1978 Argosy Minuet 6.7 Metre
Love It Here , Colorado
Images: 55
Eccotemp L5 Portable Water Heater
I did a search and did not find any posts regarding this product. I am interested in knowing if anyone is familiar with or has seen this product in use? I have found a U-tube video where it has been hooked to a back fence outside connected to a shower head for use to wash dog. It connects to a propane tank. Wonder about its use in trailers as I have read some threads about tankless, but they were all very expensive. This one is not!!!
Have also seen on Walmart ad, a Coleman camping portable hot water heater, but it has a faucet attached.
I got fed up when we spent money to replace our old Atwood and after 2yrs of faithful winterizing, came to trailer one day to find the Atwood tank had split. We hardly used it and drained it out, but there it was with big split.
I want to consider something I might be able to de-couple and take out of trailer in the winter.
Thanks for your thoughtful replies and any info you might have.
Leigh (IB Aluminated)
"When a great ship is in harbour and moored, it is safe, there can be no doubt. But that is not what great ships are built for." by Clarissa Pinkola-Estes, author of ‘Women Who Run With the Wolves’
COArgosy78 is offline   Reply With Quote
Old 06-24-2009, 05:33 PM   #2
COArgosy78's Avatar
Images: 55
I'm going to post a pic and website info as Lewster was nice enough to send me a PM on this. I want something I can remove from trailer in winter, but still utilize the fresh water tank & 12v pump, if possible. With all the great minds here on the forums, not to mention the many talents, I hope I can generate some thoughts on if this could be used. I, of course, do not want to keep it inside, but think there might, maybe be a way to set it up safely??!! Thats what I hope anyway. Hope to hear from more of you. Thanks
List Price: $149.95
Our Price: $114.50
You Save $35.45!
Availability: In stock soon. Order now to get in line. First come first served.
Product Code: L5
Description Technical Specs The Eccotemp L5 is the hottest portable tankless unit on the market! Endless hot water - wherever you are! The Eccotemp L5 unit is perfect for campsites, cabins, or simply around the house. There is no reservoir to deplete. Wash your car, wash your boat, take a hot shower, wash the dogs or the horse. You can add it to a pressure washer for an even better cleaning!. The 2 "D" cell battery ignition starts the flame only when water is running, so there's no chance of overheating.
Features
  • The ideal operating range is 20~80 PSI. The system also works great on modified water systems such as a 12 volt pump. Total dimensions are 14.5" tall, 11.5" wide, 4.5" deep and weighs about 12 pounds. Some of the other benefits:
  • 1 year manufacturer warranty on the unit
  • 37,500 BTU
  • Portable
  • 17 minute automatic safety shutoff timer
  • Includes CSA regulator for use with standard 20 lbs grill propane tank
  • Battery igniter means no electricity needed
  • On/Off shower head included
  • Garden hose adapter included
Old 06-24-2009, 06:45 PM   #3
COArgosy78's Avatar
Images: 55
Can't help myself, I'm putting a different one here. They both indicate they are usable in RV situations as long as ventilated. I really hope to get some ongoing dialogue here...
Marey®5 Liter NG & LPG Power Gas Tankless Water Heater 34500 BTU
No electrical connection necessary - LPG & NG 1.47 - 2.0 GPM
Model - 10-D Power Gas (NG or LPG)
The Marey® 5 Liter Power Gas Tankless Water Heater delivers 34500 Btu/h and saves you energy and money. It comes in both Natural Gas (NG) and Liquid Propane Gas (LPG). It's a compact unit that does not require venting, but will require that it be placed in a well ventilated area. This unit is typically used in smaller homes where one faucet is being used at one time, offices, boats, offices, cabins, boats and RVs. What makes it unique is that it requires NO ELECTRICAL hook-up. The pilot ignites by battery! Connects to standard LPG tank, like you'd use for your BBQ grill.
Owner's manual Specifications
Valve Replacement Guide
Old 06-25-2009, 07:38 PM   #4
COArgosy78's Avatar
Images: 55
I'm really sad that I haven't gotten any more response to my query
Here was my thought. Keeping the tankless unit outside, but close to the trailer, I want to hook it up to the water lines within the trailer. Does anyone think this might be possible? One of them indicates it will work w/12v pump and both work w/propane. With all the knowledge here and many DIYSers, I have high hopes that someone might come up w/an idea?
One of the videos I watched showed one of these units hanging on a post or pole of some kind. I'm going to see if I can attach it on this thread.
Old 06-25-2009, 08:06 PM   #5
Commercial Vendor
TBRich's Avatar
Profile:  2006 19' Safari SE
Tucson , Arizona
Images: 58
Interesting concept. What's to keep one from putting it in the space where the Atwood heater is/was...(not sure about the amount of space needed)...the gas source would be there, the water source would be there, and 12v would be there. And it's vented, so...
TB & Greg...and Cockers Annie & Sadie
AirForums #21900 . WBCCI F
our Corners Unit #3954
Décor Site: AZBambi Décors
TBRich is online now   Reply With Quote
Old 06-25-2009, 08:51 PM   #6
COArgosy78's Avatar
Images: 55
Yea!!! now the ball is rolling....
I actually looked at some old pics I had in my photo gallery of the Atwood metal surround (where the firing components sit) that was rusted out. It has several holes for the lines to run thru to connect to the Atwood tank. So you and I are on the same page. I am going to call the #800 on the website for one of the units tomorrow to ask if it could be kept in that area when not being used. When camping I would open the outside hinged door, connect unit to various hoses, secure it in upright position and voila - maybe??? This is why I need more dialogue. Not all that familiar w/these or plumbing issues or other contingences. Any and all are most welcome to comment. I welcome the thoughts.
Old 06-25-2009, 08:58 PM   #7
bibbs's Avatar
Profile:  Webster , New York
I tryed that, it needs a lot of ventalation ! they light up,and heat water fast
Now I am going to use it in my work shop. You should have no problem if its out side.just get some 5ft. dishwasher supply hoses, and some supply hose valves.at H.D. and a propane hose. Just hook 'em' up
bibbs is offline   Reply With Quote
Old 06-25-2009, 09:43 PM   #8
COArgosy78's Avatar
Images: 55
So when you are talking about ventilation, you are saying it should not stay in the confined area of the Atwood surround space? (where firing components are currently)? I don't think either of these units would fit into that space in an upright position (maybe sideways, but then it would not be safe to use). One of them vents out the top - so I'm thinking as long as it is upright and out of the elements, but close to the trailer so tubing can reach....
I'm going to try to attach the video I saw, if I can find it.
Old 06-25-2009, 09:54 PM   #9
COArgosy78's Avatar
Images: 55
u tube mideo of Marey Tankless
I'm hoping this will come up...
Old 06-25-2009, 09:55 PM   #10
COArgosy78's Avatar
Images: 55
u tube video of Marey Tankless
Old 07-01-2009, 06:41 PM   #11
COArgosy78's Avatar
Images: 55
I'm baaaaccckkk
Went out to CW this past weekend to look at the EccotempL5 in person. They were sold out and backordered I have gotten the Eccotemp #800 and found that they have been swamped w/orders so it will probably be several weeks before CW will get any. I can have one put aside once they arrive, but will be awhile before I get up close and personal.
One thing I wanted to clarify, if someone can. I was told while at CW that it is the 12v pump that will determine whether the incoming water will reach it's destination?? All of the videos of these units show them being used w/shower head right next to the unit. Since I am wanting to tie into existing water lines to run to kitchen sink & bath sink/shower from where the unit will be located outside, I was concerned about distance. But I was told several times that it does NOT matter how far away the faucet/shower head is, but does matter the pressure being sent by the pump. The EccotempL5 does best w/40psi, the EccotempL10 w/65psi. I can't remember or maybe never knew what the 12v pumps in our trailers will do - altho 40-60psi sounds right?? I've been told that an HVAC pro can probably answer any/all of my questions - what is HVAC???
Old 09-21-2009, 02:40 PM   #12
Profile:  1971 31' Sovereign
Ocala , Florida
HVAC is Heating, Ventilation, & Air Conditioning. I really like your idea here and I have the same one, but I am a long way from getting to re-plumbing yet. I am still working on frame repairs and replacing sub-floor. have you gotten any further with working through your idea to use this item?
cjohannesen is offline   Reply With Quote
Old 09-21-2009, 04:21 PM   #13
COArgosy78's Avatar
Images: 55
Hey, thanks for responding to my ????. I love the way these posts go away for awhile, then pop back up! To answer you ???. No, I had 2 projects I wanted to get done this year (actually 3, including our new axle). The one I have taken on right now is getting some window protectors on our wrap windows. I think all the hail storms this year put a scare in me. I have talked w/several people about this WH idea, and it seems a very plausible one, just trying to make sure I have a better grasp of the whole plan. Maybe I will purchase one of these tankless units and make it to a rally. Many heads are definitely better than my one!!!!! If you go with it, please post here as I am very sure this is what we will get to eventually.
Old 09-21-2009, 06:11 PM   #14
Profile:  1985 31' Excella
battle ground, , Washington
video did it for me!
In my AS i have the standard water heater, and of course, I do not leave it on. So, it takes awhile to get hot water once we have arrived...and are ready to use some hot water-this unit or something like it will be in my trailer by jan '10-instant hot water is what it is all about. I see absolutely no reason why it cannot be put into the standard hwh space with appropriate mods. I am also considering a small electric tankless for in the galley-ya always want hot water when the unit aint on and you think maybe i'll wait awhile....you know what I mean. instant is a good answer to rv'ing.
wmarsha is offline   Reply With Quote
any feedback on this portable water heater? greenrig Furnaces, Heaters, Fireplaces & Air Conditioning 3 05-29-2009 09:21 PM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 08:17 AM
Reeling in the Sheaves…. Portable catalytic heater installation hshovic Furnaces, Heaters, Fireplaces & Air Conditioning 4 10-23-2007 10:14 PM
Portable heater suggestions ALANSD Furnaces, Heaters, Fireplaces & Air Conditioning 4 11-22-2005 03:54 PM
Cleaning the portable water systems after use Silvertwinkie Fresh Water Systems 4 07-01-2003 04:46 PM
