Old 11-03-2011, 08:54 PM   #57
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Just getting to your tankless water heater post. Wondering, has anyone switched out their existing Atwood tank water heater for this tankless?
Looking at the video, in order for the Marey tankless to work in an Airstream, you'd either have to do quite a bit of modifications to Airstream, or is the Marey able to be installed on it's side, so venting could be accomplished?
Love to know if anyone has made this change to tankless. If anyone has, can you tell a difference in LP usage? More propane? Less propane?
Thanks, Derek
Old 11-04-2011, 02:58 AM   #58
Akron , Ohio
It won"t work on it's side, it must be upright.
prudencepb is offline   Reply With Quote
Old 09-06-2012, 05:12 PM   #59
mogadore , Ohio
anyone have any pictures of their Marey water heater installed? I bought one for my Airstream ( different Brand) and I ran the water lines.The only thing I havent figured out yet is how to vent it. Should I go through the Roof or put a 90 on it and take it out the side. I posted pictures of mine hanging on the wall on a thread the other day.
Marchok is offline   Reply With Quote
Old 09-08-2012, 12:16 PM   #60
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
Marchok, follow the mfrs instructions about venting, tankless put out a lot of exhaust. You should also think about intake air as they need a lot of combustion air too. I'm speaking from experience with on demand in dwellings, not in trailers, but I imagine they're similar. We just had an Atwood 6 gal with electronic start installed, rather pleased with the performance.
Wherever you go, there you are
Globie64 is offline   Reply With Quote
any feedback on this portable water heater? greenrig Furnaces, Heaters, Fireplaces & Air Conditioning 3 05-29-2009 08:21 PM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
Reeling in the Sheaves…. Portable catalytic heater installation hshovic Furnaces, Heaters, Fireplaces & Air Conditioning 4 10-23-2007 09:14 PM
Portable heater suggestions ALANSD Furnaces, Heaters, Fireplaces & Air Conditioning 4 11-22-2005 02:54 PM
Cleaning the portable water systems after use Silvertwinkie Fresh Water Systems 4 07-01-2003 03:46 PM
