Old 01-12-2018, 05:16 PM   #1
2016 16' Sport
Cedar Park , Texas
Does water pump need to be turned off?
We have disconnected the city water because of expected below-freezing temperatures. We have filled the fresh water tank and it is working fine with the pump turned on. Since we will be here for a few days, is it OK to leave the water pump switch on full-time? Or should we have it on only when we need to draw the water?
edlong56 is offline   Reply With Quote
Old 01-12-2018, 06:05 PM   #2
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
On all the time is fine. The pressure switch will activate the pump when a faucet is open or toilet is flushed. Then turn the pump off again when things are not flowing water.
No black magic or anything to run battery down, just plain old simple is or ain’t.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 01-12-2018, 06:05 PM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
I leave it on if I am at the trailer and turn it off if I leave.
CRH is offline   Reply With Quote
Old 01-12-2018, 06:06 PM   #4
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
we always leave ours on, but turn it off if we're leaving the AS unoccupied
rbs is offline   Reply With Quote
Old 01-12-2018, 06:14 PM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Turning the pump off while away is a good practice.
If someone leaves the pump on while away from the trailer and there happens to be a leak in the pipes, the person could return to a flooded interior and/or loose all of their fresh water supply.
Alan
Old 01-12-2018, 06:29 PM   #6
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
Agree, leave it off!
I dont know if you can burn out a pump, but if you break a pipe, you can sure flood your rig quick.
Also, if you dont need hot water for a while, turn it off too. Saves propane and a burnt out system if it runs dry due to a leak or your water pump being off.
WayneG is offline   Reply With Quote
Old 01-12-2018, 06:31 PM   #7
1981 31' Excella II
New Market , Alabama
Not a bad idea to turn it off when you leave or at night so if it sputters it won't wake you up. Usually there is enough pressure to flush the toilet with it off.
Perry
Old 01-12-2018, 06:52 PM   #8
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
How many turn off the city water when leaving the trailer or going to bed when on water hookup? If you don't then why worry if the water pump is on all the time?
I just replaced my Aquajet pump with a Shurflo 4008 and added the Shurflo accumulator tank adjacent to the pump. Much quieter and smoother. I usually leave it on all the time except when towing.
Kelvin
Old 01-12-2018, 09:39 PM   #9
1986 31' Sovereign
Miami , Florida
Actually, I do shut off the water if I am going to be gone awhile. Paranoid, I guess...
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 01-12-2018, 10:45 PM   #10
CRH
1995 25' Excella
xxxxx , xxxxxx
I also shut off the city water if I am leaving for a while.
Old 01-12-2018, 11:17 PM   #11
2007 22' International CCD
Paranoid? No, one single noid is quite enough...
Shutting off water pump or shore water supply is just proactive safety...
Old 01-13-2018, 08:39 AM   #12
GettinAway's Avatar
2011 23' FB Flying Cloud
Chesterfield , Missouri
I shut it off whenever I leave. Shut it off at night too. There's enough pressure to flush the toilet. Our pump is close to the bed though. I turn off the propane hot water at night also. Lite sleepers I guess. Ive bought a quieter fan for the fridge, but haven't installed it yet, so I also turn it off at night.
The main reason I turn off the pump though is a potential leak. Those plastic pipes that freeze and thaw all winter, then bounce around up and down the highway.. We have never had a leak, but I wouldn't want to find one that way..
2011 FC 23FB
2012 Toyota Tundra Dbl Cab, 5.7 4x4
GettinAway is offline   Reply With Quote
Old 01-13-2018, 09:18 AM   #13
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs down ...at 3am
......we learned our lesson, second outing.
Supply line under bathroom sink, a cross threaded fitting cracked.
We now turn the pump off when sleeping or unoccupied.
BSTS
POI..We have never been "hookrd-up" But would shut off there also.
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on fire.
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 01-13-2018, 09:48 AM   #14
Mollysdad's Avatar
I turn mine off when not using it.
Turned off fridge to defrost, won't come on w/elec., will with gas BrianD. Refrigerators 20 12-13-2010 01:02 PM
2004 Classic Limited shower valve leaks hot water when turned off? myrnaw Fresh Water Systems 1 08-02-2010 08:34 AM
'98 30' LY MH... Water comes out filler vent when pump is turned on. Help! WeLoveToCamp Land Yacht/Legacy Motorhomes 3 07-19-2010 08:04 PM
Faucet is running when turned off Stefrobrts Sinks, Showers & Toilets 5 04-24-2010 09:22 PM
Turned off by the new Safaris Raptorrider2001 Our Community 17 09-08-2005 02:33 PM
