Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 08-09-2014, 12:13 PM   #1
2PNPOD's Avatar
1971 18' Caravel
Columbus , Montana
Do water heaters come w/shut off valves?
My 71 Caravel has water leaking out from the outside water heater access panel. I'm not sure what's leaking, the valves to/from or the tank itself.
We were planning a two-day trip tomorrow and was wondering if there's a water heater bypass valve, or some way to stop the water from entering the water heater. We don't really need hot water for this trip, but can't have it leaking.
Any suggestions would be awesome.
Thanks everyone.
Scott and Val
1971 Caravel - Pea Pod
2006 Dodge Ram 3500 - 325hp 5.9L Cummins turbodiesel
2PNPOD is offline   Reply With Quote
Old 08-09-2014, 01:13 PM   #2
1974 Argosy 20
Kooskia , Idaho
Val, Scott:
Unfortunately there are none on your Caravel. None from the factory, and I didn't add any or change the water heater plumbing when I owned it. Also see PM.
Rob (your PO)
Old 08-09-2014, 01:16 PM   #3
2PNPOD's Avatar
1971 18' Caravel
Columbus , Montana
Thanks Rob, just saw your PM. It's certainly great to hear from you and see you on the forums! Were looking at your response now...
Thank you THANK YOU for your help. I'll let you know what we find out.
Scott and Val
Old 08-09-2014, 01:18 PM   #4
Argosy 7728's Avatar
1977 Argosy 28
Irrigon , Oregon
On my 77 there are 3 valves by the water heater inside the cabinets. Close the 2 that are on the lines going into the water heater. Then 3rd valve is a bypass valve, I open it when I put anti freeze in so none of it enters the water heater. Mine still has all the factory plumbing. So all this is assuming that someone has not changed something.
(edit)Well never mind, I just learned something new. LOL
Rod
AIR# 60278
Argosy 7728 is offline   Reply With Quote
Old 08-09-2014, 02:05 PM   #5
Kevin245's Avatar
Have you checked the T&P valve to see if that is the leak source?
William C. Swinney
Old 08-09-2014, 03:15 PM   #6
2PNPOD's Avatar
1971 18' Caravel
Columbus , Montana
Argosy & Kevin, thanks so much for your replies. We have the water heater out and are working on tracking down the leak; either in the water tank itself or the connections. Not sure just yet as we have only just removed it. Will hopefully get some pics posted.
Scott and Val
Old 08-13-2014, 03:53 PM   #7
2PNPOD's Avatar
1971 18' Caravel
Columbus , Montana
New Atwood 6 gal water heater on its way from vintage trailer supply (great folks). Hoping to have our plumber do some pex mods once this baby arrives. Looking forward to the electronic spark ignition!
Scott and Val
Old 08-26-2014, 02:52 PM   #8
2PNPOD's Avatar
1971 18' Caravel
Columbus , Montana
Water heater is going in today, hoping to go camping tomorrow
We purchased the Atwood 6 gal direct spark ignition. Only thing I haven't researched is what to use as a sealer around the water heater flange/airstream shell
Scott and Val
Heaters, heaters, heaters. doorgunner Furnaces, Heaters, Fireplaces & Air Conditioning 80 12-02-2013 10:20 AM
Inline Propane Shut-off Valves?? SLNugget LP Gas, Piping, Tanks & Regulators 8 09-14-2012 10:52 AM
Black water shut off valve? '73 Sovereign Al Falcon Waste Systems, Tanks & Totes 10 05-14-2007 04:28 AM
External Water Shut-off on FB units wheel interested 2006 - 2010 Classic (all lengths) 8 09-09-2006 11:12 PM
Gas shut off valves Sneakinup Water Heaters, Filters & Pumps 1 02-04-2004 10:19 AM
