Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 11-15-2013, 11:34 AM   #1
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Do I HAVE to use an anode rod in Suburban Why?
I like to empty my water heater each time I come back from camping. The anode rod in the Suburban water heater makes that task kind of a pain. My Atwood WH doesn't have an anode rod, so it's an easy thing to empty the tank. Can I lose the anode rod in the Suburban water heater?
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 11-15-2013, 12:03 PM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 61
If the tank is steel YES.
Atwood WH is aluminium.
Dave
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
Old 11-15-2013, 01:45 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
As Dave said, the Atwood tank is aluminum and does not use or require an anode.
Suburban tanks are steel. You can remove the anode, but doing so will shorten the life of the tank, especially if you travel in areas where the water is corrosive.
Water in Minnesota is calcium-laden and isn't corrosive, and people remove and throw away anodes in their water heaters (stick house, RV, doesn't matter) all the time here.
I don't know what the water is like in Indiana.
More here:
Lesson 8: Corrosion Control
Old 11-15-2013, 06:45 PM   #4
Becky B.'s Avatar
1964 17' Bambi II
Ok, I guess I'll have to stick with anode rod. Shoot!
Becky
1964 Bambi II
1988 Avion 32S
