Old 09-29-2005, 10:36 AM   #1
yukionna's Avatar
Massachusetts
Images: 18
Send a message via Yahoo to yukionna
Dissection of a Bambi II water heater
We recently replaced our leaking water heater in our Bambi II. Rather than getting rid of the water heater, I'm thinking it might be useful if I "dissect" the water heater, take pictures and post them to the forum with the hopes of helping others down the line. I'm thinking a good place to start would be to cut it in half.
With that said, can anyone offer up any advice on the best tool to use (I have a sawz all) and the best angle to make the initial cut through?
WBCCI Region One
Attitude is the only difference between ordeal and adventure
yukionna is offline   Reply With Quote
Old 09-29-2005, 05:31 PM   #2
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Hey. If you want, I can cut it in 1/2 at work, we have really big toolz
JUst bring it along to the rally?
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 09-29-2005, 07:20 PM   #3
yukionna's Avatar
Massachusetts
Images: 18
I will take you up on that offer! How big and what kind of tool would you use? (just curious)
WBCCI Region One
Old 09-30-2005, 07:13 AM   #4
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
We have Vertical band saws that can cut up to 2 feet.
www.balrgn.com
Old 09-30-2005, 09:41 AM   #5
NorCal Bambi's Avatar
1963 16' Bambi
Yreka , California
Images: 21
Water heater from space
I have a 63 Bambi that I am currently restoring. The water heater is a Bowen model. I have completely taken it apart. The aluminum tank has a split in the top weld from freezing. I plan to repair this heater. How would you like to compare notes? Attached is a fun picture I made using the aluminum inner tank of the heater. thought I'd share it with you.
UFO sighted over Northern California
I was working out back on my 1963 Bambi in the hot sun when I made the sighting. I ran and got my camera and snaped this image of the UFO. I have included the picture so you can see what hard work will get you.
- Give karma
NorCal Bambi is offline   Reply With Quote
Old 09-30-2005, 10:06 AM   #6
yukionna's Avatar
Massachusetts
Images: 18
Originally Posted by NorCal Bambi
I have a 63 Bambi that I am currently restoring. The water heater is a Bowen model. I have completely taken it apart. The aluminum tank has a split in the top weld from freezing. I plan to repair this heater. How would you like to compare notes?.
Cute photo...thanks for sharing.
We didn't realize that water heater's could be repaired so never considered it. Can you direct me to the best means to take it apart as I may want to actually repair it (if the task isn't too daunting).
WBCCI Region One
Old 09-30-2005, 05:41 PM   #7
1963 16' Bambi
Yreka , California
Images: 21
Hot Water Heater Bowen
My tank had the top cut off to check the inside for oxidation damage. It was in good shape. The top was heli arched back on. Cost $90. My General Controller #11000-e is in bad shape. It will probably be hard to impossible to find. But I' going to try. Does your old tank have one and would you be willing to sell it?
Thanks Don
Old 10-01-2005, 04:28 PM   #8
yukionna's Avatar
Massachusetts
Images: 18
Let me take a look at what I have when I open it up. Can you post a photo of what a General Controller #11000-e looks like so I know what I'm looking for?
WBCCI Region One
Old 10-01-2005, 05:48 PM   #9
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
If you were way down he-yah in the South, you would cut one of the ends off, and use the tank as a peanut boilin' pot.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 10-01-2005, 06:02 PM   #10
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
What the heck do you do with boiled peanuts?
www.balrgn.com
Old 10-01-2005, 06:12 PM   #11
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
Images: 36
Why you eat them, of course! Here in the South, boiled peanuts are very popular. Green, or immature peanuts are boiled in salt water, with and without seasonings, such as pepper and garlic, until they are soft or semi soft. To a Northerner, the first time you try them, you probably will not like them. It is an aquired taste, like scotch
Most peanuts are boiled in aluminum pots, or beer kegs with the tops cut off.
ARS WA8ZYT
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 10-02-2005, 10:31 PM   #12
1963 16' Bambi
Yreka , California
Images: 21
Talking Ufo
Has no one else ever taken apart a Bowen water heater? MY UFO's are the tanks inside a Bowen heater. Maybe this is a sign of how much (good sence) I may or may not have. My wife said it looked like a flying saucer. When I was taking the primary pictures a passerby stated,( You have too much time on your hands). Well it's late I think I'll get some rest.
Old 10-23-2005, 07:06 AM   #13
1963 16' Bambi
Yreka , California
Images: 21
Water repair
On the Bowen water heater the tank is made of aluminum. The first thing one needs to do is take the tank to a certified welder and have the top cut off to see what the condition of the metal is inside the tank. Corrosion is a major factor. My tank looked really good inside. So I had the tank re welded and pressure tested. Included in the pictures is the inside tank and the outside tank parts. To remove the outside tank one must first remove all the items connected to the outside of the tank. Then the galvanized lid can be removed using a large, 1", cold chisel and a hammer. Start by placing the chisel in the grove that surrounds the tank on the part of the top that wraps around the sides of the tank. Continue taping and moving around the tank. You will probably have to go around the tank several times until the top will pop off. If you tap too hard you can puncture the galvanized metal. Not hard enough and you will get no where. Start soft until you get a feel for what you are attempting to do, and then move on. The bottom will come off in the same way. Remove all insulation and then remove the inner tank from the outer. The inspection and welding of my tank cost $90. My guess so far is that I could have probably replace the tank with a new on for about the same cost. However my goal is to try ant keep the trailer as original as possible. The UFO project just seems to go along with the 50's and 60's.
Name:	tank inner.jpg
ID:	15344   Click image for larger version
Name:	tank outter.jpg
ID:	15346   Click image for larger version
Name:	UFO with flame 3.jpg
Old 10-23-2005, 09:36 AM   #14
Images: 59
Here is another thread on reconditioning a Bowen.
http://www.airforums.com/forum...3&postcount=10
(You can read the rest of the thread by following the link in the upper right corner.)
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 05:03 AM
Water Heater shell frame BobbyW Water Heaters, Filters & Pumps 0 04-29-2002 10:21 AM
Water heater work tool FrankR Water Heaters, Filters & Pumps 1 04-09-2002 10:57 AM
