Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 02-19-2003, 07:02 PM   #1
JLD
Profile:
Difficult Hot Water Lighting
Hello. It seems to take forever to light my hot water heater. I have taken to turning the blue dial to pilot and then just sitting there a while, holding it open, until my hand gets tired and then trying to light it. It tries to light, spits and sputters and finally gets a stream of propane going that is sufficient to light a pilot that will stay lit for the 40 sec needed. Has anyone any suggestion as to the cause of and the solution to the problem. I sort of think that while we are gone, two to four weeks, condensation develops along the line and has to be blown out by the pressure of the gas before it will light.
Joan
JLD is offline   Reply With Quote
Old 02-19-2003, 07:31 PM   #2
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
Joan, once you get the thermocouple hot enough, the main gas valve will open to the main burner, and it will light. The 40 second delay is for safety, to prevent a large amount of gas building up enough for an explosion. Sore fingers are better than dead fingers. Using a butane grill/campfire lighter instead of matches. Wally-World has a pack of two for $3.49.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 02-19-2003, 08:24 PM   #3
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 104
Greetings Joan!
Two thoughts on possible issues that might cause your pilot lighting problem. The first is the possibility that an insect may be part of the cause - - spiders seem to love building their nests inside the air mixture tube, and this causes the pilot to either be difficult to light or if it lights the burner runs so rich that black soot covers the exhaust of the water heater (the tube can be carefully removed and cleaned with a small, soft bottle brush; and then replaced on the water heater). A second possibility, if this happens primarily after a period of not being used, especially if the propane has been turned off at the main tank valves, it may be air in the lines - - one way that I deal with this on my Overlander is to light all four burners on the range and wait for their flames to stabilize before I try lighting any of my other LP appliances.
It is also a possibility that the burner may need cleaning and adjustment.
Good luck in finding the source of your difficulty.
Kevin
Kevin D. Allen
AIR #827
Old 02-23-2003, 03:48 PM   #4
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
On older water heaters I have used a butane fire lighter with the long tube and just held it under the thermocouple until the main burner will light. The opening of the gas valve is sufficent to purge the lines of air. It may not be the safest way, but it works.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Nobody needs a hot water heater!!! Rick Alston Off Topic Forum 109 02-13-2004 09:52 PM
Lighting Hot Water Heater hhuber Water Heaters, Filters & Pumps 14 04-01-2003 09:31 AM
Another faucet question--no hot water... heyskipper Sinks, Showers & Toilets 3 03-13-2003 06:06 AM
Hot water piping Pahaska 2003 International 8 01-29-2003 07:19 AM
Looking for ideas hot water FrankR Water Heaters, Filters & Pumps 3 05-09-2002 10:28 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
