Old 01-11-2015, 04:19 PM   #1
2014 23' Flying Cloud
Salida , Colorado
Dewinterization problem with hot water heater
Hi: We had our 2012 Flying Cloud winterized and now are in AZ where we are now using it. But we cannot get the hot water heater to heat and provide water. A small stream of water comes out the hot water faucet, but it is not hot. Cold water works fine. We have it hooked up to city water. I turned on the right switch at the vanity and it seems like the system is on. I think I used to use the left switch. Can someone help? Thanks, Kathy
vakathy is offline   Reply With Quote
Old 01-11-2015, 04:21 PM   #2
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Is the water heater bypass open? Check the valves behind the water heater.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 01-11-2015, 04:30 PM   #3
dznf0g's Avatar
Oswego , Illinois
If yours has it, the silver mixing valve is notorious for getting it's screen plugged up with the crusties out of the tank, especially after using the first time after a drained tank. All the crusties get stirred up when filled the first time.
-Rich-
Old 01-11-2015, 04:32 PM   #4
Ron A's Avatar
2018 23' Flying Cloud
Huntsville , Alabama
May check the water bypass value for the water heater. Common to turned off when winterizing travel trailer.
Ron
Ron A is offline   Reply With Quote
Old 01-11-2015, 04:46 PM   #5
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
First, try filling the water heater by opening a hot faucet (before turning on the heater) until you have a good stream of water coming out, and it doesn't spit at you. When it spits, you're getting rid of air bubbles in the plumbing.
But if you never get a good stream of water that way…
Bleed some of the air out of the water heater by opening the pressure relief valve at the top. Don't let ALL of the air out (you want a small cushion of air at the top) but some of it. This will allow the water heater to fill.
Not allowing the heater to fill completely before turning on the heater will cause symptoms exactly as you described. It happened to me just last week and I hadn't even winterized; just changed out the drain plug for a drain valve, which of course required draining the heater.
Cats and ultraleather Airstream upholstery don't mix!
Old 01-12-2015, 09:34 AM   #6
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Be sure your water heater is full before turning it on. Then follow the advice you find here.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 01-12-2015, 11:00 AM   #7
jackson center , Ohio
Check to see if the water heater by-pass valve is in the correct position on the back side of water heater.
Schu is offline   Reply With Quote
Old 01-13-2015, 08:57 AM   #8
Salida , Colorado
De-winterization
You've all been very helpful - it was the hot water heater by-pass. The problem was was that we could not find it. - It's under the bed. Live and Learn!
Old 01-13-2015, 04:21 PM   #9
Castaway's Avatar
2012 25' FB Flying Cloud
Celina , Ohio
I am having the same problem with our 2012 FC. The water flow coming out of the Hot water faucet is about half of that from the Cold faucet. When I open the petcock on the water heater I get a good flow of water out of it and it is extremely HOT!!
So far I have checked the water flow coming into the heater and it is fine, removed the mixing valve and soaked it in Calcium/Lime remover with no improvements. I NEVER TURN OFF the bypas valve so it is open. I also get a good flow from the low water drain located next to the water heater
The water is not hot when does come out of the faucet. Is my next move buying a new mixing valve?
Gary
Castaway is offline   Reply With Quote
Old 01-14-2015, 10:17 AM   #10
Castaway's Avatar
Celina , Ohio
Thanks to Protagonist suggestion of bleeding some air we now have hot water
Gary
Old 03-21-2015, 05:12 PM   #11
2004 25' International CCD
2012 25' International
slaton , Texas
low pressure from water heater / crusties
i am having the same problem on my 2012 International 25'.. this was our 2nd trip. I did winterize in 2014 , used it in 2/2015, winterized again. and went out this week (3/16). tested b4 we left in hooking up to city water and checking all faucets for good flow, all ok. (never energized water heater) did have a small drip at the water heater drain plug, so I was going to put some tape on it and when I opened it a gush of water under a lot of pressure came out. on this last trip we had a full stream of cold water with about 10 % luke warm. ( all screens on faucets were cleaned) the by pass was never touched, as I did not find it until this trip. it was in the normal position for city water... we have never used the fresh water tank only the city supply. I did clean the strainer for the fresh water tank when I winterized but that should not affect the city water supply flow... is there another filter for the city water that I do not know about? I did leave the water heater plug out when I winterized and thought that a critter/insect might have nested in the hot water line.
any advise on what I need to do?????? this stuff drives me crazy.. thanks in advance for any information.
gnowlin is offline   Reply With Quote
Old 03-21-2015, 10:23 PM   #12
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
There is no specific position of the bypass valve when on city water.
The water heater is bypassed for winterization. Most bypass systems have three valves. Some have two three way valves instead.
The bypass valve should be closed and the valve on the hot and cold side of the water heater should be open for normal operation.
By normal operation I mean you can use city water or "house" water. House water requires the FW tank to have water in it and the pump should be turned on to supply water to the sinks etc.
When the water heater is filled by either method. There is an air space at the top of the unit. It is an expansion chamber for when the water gets hot.
You obviously charged the water heater. Thus the gush of water when you pulled the drain plug.
I think you have the bypass valve open. Thus the reason for the luke warm water.
Old 03-22-2015, 06:13 PM   #13
slaton , Texas
thank you very much..there is only 1 bypass valve that I can see, and it is apparently open. ( handle is lined up parallel to the supply line) we have only done 2 trips in this trailer and the first trip we had hot water. ( valve has always been in the same position.) I tried turning the by pass after water heater was on but no increase in pressure, could be I did not have it on long enough. so the only thing the by pass does is bypass the water heater for winteri zing?. I thought it was to by pass city water for house water for filling the heater. I just have never been told or could find anything about what it does. tks for the insite!! when the gush came out I had just filled the water lines and did not turn on the heater. we did have a full flow in cold and hot sides ( again this was prior to water heater being turned on and before we left for our trip). once the water heater was turned on is when we had only 10% flow and warm water. open the pressure relief and had very hot water. ( that's all after we were camped and needing hot water.
do you think this is a pressure problem or a crud in the lines? is there another filter for the hot water?.
Old 03-22-2015, 08:09 PM   #14
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Follow the water line that is connected to the cold water side of the water heater. It will be close to the bottom. There should be a valve in that line to shut the water off to the water heater. The handle will be perpendicular to the line when off. The cold water shutoff valve will be between the bypass valve and the water heater. For normal operation the handle should be inline with the pipe. The same goes for the hot water side except the connection point on the water heater is close to the top.
The bypass valve is closed during normal operation and the other two valves (hot and cold) should be open.
Thus the cold water enters the heater and the hot water exits the heater. If the bypass is open the water takes the path of least resistance.
Hot hot hot aluminum! 58cruzer General Repair Forum 23 06-24-2013 01:08 AM
Hot water heater and water pump xo1rider 2011 - 2015 International 3 10-12-2012 06:55 PM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
Hot Water Heater Problem Solved Larry71 Water Heaters, Filters & Pumps 5 04-19-2009 12:29 AM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
