Old 05-22-2009, 11:07 AM   #1
2007 31' Classic
Social Circle , Georgia
Delta Under Sink Water Filter
I'm stuck here.......the water filter that is under the kitchen sink (it is made by DELTA) has no water pressure at all.....it would take 3 - 5 minutes to fill a water glass.
I contacted Delta customer support and was told to get a new cartridge, soak it for a couple of hours before inserting it, and after inserting it, to press and release the pressure valve several times. No change at all.
The only way we can get any water pressure from the filtration system is while holding that pressure valve down.
Any help is appreciated.
evanskl is offline   Reply With Quote
1969 Overlander Int'l water question - filter on outside water hook up? edmund015 Water Heaters, Filters & Pumps 3 08-20-2009 10:30 PM
under sink water filter advise Safari64 Water Heaters, Filters & Pumps 3 04-08-2009 07:28 AM
Water Pressure Regulator & External Water Filter safarijim Off Topic Forum 7 02-01-2007 08:17 PM
Under sink drinking water filter wacnstac Water Heaters, Filters & Pumps 7 04-05-2006 03:01 AM
Need a Water filter under sink w9det Water Heaters, Filters & Pumps 7 06-29-2005 06:15 AM
