Old 05-23-2019, 01:30 PM   #1
RFP
RFP's Avatar
2014 23' International
Hurst , Texas
Debris in the WH mixing valve... what are the chances?
Our Airstream is a 2014, and it has been a problem-free delight.
We have been noticing that there is probably 30% reduction in water flow when using hot water as compared to the cold water flow.
The aerators are perfectly clean, so I'm wondering if perhaps there is some 'crud' collected on the screen of the water heater mixing valve. I know that it's pretty easy to check, requiring only minor disassembly, but being a lazy lout (!), I thought that I would check with the brain trust.
As always, thanks for your help.
Robert
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is online now   Reply With Quote
Old 05-23-2019, 01:38 PM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Are you talking the sinks and the shower? If it is just the shower, I had that problem and the guts of the cheap plastic Moen valve were broken. I replaced the insert with brass and everything has been fine since.
Larry
lsbrodsky is online now   Reply With Quote
Old 05-23-2019, 01:42 PM   #3
RFP
RFP's Avatar
Hurst , Texas
Larry
Thanks, Larry, for helping me think about this. It's both sinks... I didn't even check the shower, thinking it would follow the same pattern.
Robert
And some stuff
Old 05-23-2019, 04:12 PM   #4
Long Island , New York
If you have not been religious in using an inline water filter for city water and for filling your water tank, since the trailer was new, debris in the mixing valve is a definite possibility IMO.
https://www.google.com/search?q=mixi...=airforums.com
It is also possible that your mixing valve has simply started to fail.
The same debris can get into the water pump, and cause all kinds of back-flow problems into the [overflowing] water tank, when on city water:
https://www.google.com/search?q=wate...=airforums.com
Even so-called pristine city water can have grit in the lines, at times, and rural campground well water can also be full of grit.
Good luck,
Peter
PS -- Camco filter, one of many brands:
https://www.amazon.com/Camco-40645-T...gateway&sr=8-3
Old 05-23-2019, 04:50 PM   #5
RFP
RFP's Avatar
Hurst , Texas
[QUOTE=OTRA15;2244433]If you have not been religious in using an inline water filter for city water and for filling your water tank, since the trailer was new, debris in the mixing valve is a definite possibility IMO.
< snip >
Well, Peter, in an uncharacteristic burst of initiative and energy, I went ahead and pulled the mattress out and lifted the plywood bed base and took the mixing valve out along with the check-valve (which is a separate part).
There was only the slightest amount of crud in there, but I brought both pieces in, put them in our electric teakettle and boiled both in white vinegar (don't tell Linda, I don't think she's completely forgiven me for cleaning SU carburetors in the kitchen sink back in the 60s).
Anyway, I put my shiny clean parts back together and tested it for operation (and leaks!). I'm proud to say there are no leaks and - and I really don't know why this is - there seemed to be an increase in flow when either faucet is turned to full hot. I don't think this is simply the "Hawthorne Effect" (you know, it just "got better" because I fiddled with it)... the flow is definitely higher.
So, that's my story, and I'm stickin' to it
And some stuff
Old 05-23-2019, 07:31 PM   #6
Good news!
Your "Manitas de Plata" did the trick, I guess?
Good to know that microscopic mineral deposits could have been part of the problem.
Peter
Old 05-23-2019, 09:13 PM   #7
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
My mixing valve stopped working completely this spring. After just 2 seasons and maybe 70-80 nights here is what had built up on the mixing valve screen....
I replaced the valve. Old one is a spare... just need to get around to soaking in vinegar....
wulfraat is offline   Reply With Quote
Old 05-24-2019, 10:16 AM   #8
CruizinDux's Avatar
Tracktown USA , Oregon
To complete the picture so to speak here is wulfraat's post/thread that i had saved. I'm planning on this project when i replace my BW vac breaker/ ck valve next mo. Thanks for the pics wulfraat!
http://www.airforums.com/forums/f445...-177432-2.html
B
CruizinDux is offline   Reply With Quote
Old 05-24-2019, 03:50 PM   #9
2019 25' International
Washington , Washington, D.C.
So where would I find this mixing valve?
PatLee is offline   Reply With Quote
Old 05-24-2019, 03:55 PM   #10
RFP
RFP's Avatar
Hurst , Texas
On the back of the water heater.. Click on the link in post #8 above
And some stuff
Old 05-24-2019, 04:05 PM   #11
2007 22' International CCD
Note that not all water heaters have one.
rmkrum is online now   Reply With Quote
Old 05-24-2019, 04:33 PM   #12
1972 31' Sovereign
Chicago , Illinois
Mixing or pressure balance valve?
Guess my classic '72 doesn't have one. Is this pressure balance valve?
open01 is offline   Reply With Quote
Old 05-24-2019, 04:44 PM   #13
It mixes very hot water from the water heater tank with cold water. In effect it gives about 9 gallons of hot water from a 6 gallon tank of scalding hot water.
We went tankless because DW needs her long hot showers on the road. The tankless puts out hot water as long as we have water and propane...and she’s happy with that!
Old 05-25-2019, 08:06 AM   #14
wulfraat's Avatar
rmkrum - what tankless heater did you go with? Was it a drop in replacement for the Atwood or did you have to change the opening size in the outer skin? Did you self install?
All the Atwoods in late model airstreams have a mixing valve. On my last trailer I went 8 years no issues. The new one had to deal with clogging after just 2 seasons. Must be the Rocky Mountain water.....
What are the chances I have Mold?!? Jakattack General Interior Topics 9 04-02-2017 06:34 AM
Atwood XT Water heater mixing valve orloffgray Plumbing - Systems & Fixtures 0 03-23-2016 07:55 AM
Who says there no second chances? VtTim All Argosy Trailers 2 09-13-2013 05:45 PM
Need mixing valve G. Traveler Sinks, Showers & Toilets 5 11-01-2011 06:15 PM
What are the chances of this- 2006 Classic? thecatsandi 2006 - 2010 Classic (all lengths) 1 03-29-2008 05:27 PM
