Cycling Water pump with no water leaks
Hey Gang-
A new issue has evolved. I have a water pump which has started to cycle in very short bursts (about a second) about once every five minutes. This would seem to indicate a low flow leak somewhere. Try as I might I can not find it anywhere!!
I am beginning to suspect a pressure switch problem but I haven't gotten into the pump yet.
After I put in a new water heater, I pressure tested with air at 30 psi (as per the water heater installation instructions) and checked everything with soapy water, like a propane system bubble test. All systems looked great... but
The bloody pump cycles! any suggestions???
Thanks in Advance
The Professor--
Alex Kensington, Full Timing with
Charon Henning, The Most Dangerous Beauty Alive™
1966 Safari Overlander & 1961 Safari
1956 Spartan Imperial Mansion
TCT Since 2002, 8728,
