Just got back from a trip to Dallas to spend Thanksgiving with our daughter and new grandson.
The water heater in our 2000 Safari worked fine for about 4 days and then it started acting up. It would fire up and run for about 20 or 30 min and then lock out. It would not start up again until everything cooled down. Then it would run again for about 20 min.
Another symptom is that the pressure relief valve dribbles even after opening and running the hot side of a faucet to relieve pressure.
The water heater on our previous trailer was unreliable also.
Any suggestions before I get an electric heater element?
It sounds like the thermostat is not working and it is overheating the water. This could be why the relief valve is "leaking", and the unit is shutting down, until cool. Does the hot water seem REALLY hot? Does the unit have electronic controls, or is it a standard pilot ignition type water heater?
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce! Air # 283
WBCCI 1350
Yes, the water does seem pretty HOT!
As far as your other question, the unit is a standard unit with electronic ignition(no pilot light).
Thanks for any suggestions.
I had the same problem with mine. I replaced the pressure relief valve and that solved the problem. I think Atwood used the cheapest valve they could find.
Jerry Sullivan
'01 Limited
'01 Safari
On The Road, USA
