Old 12-02-2002, 08:48 AM   #1
2000 27' Safari
Wappapello , Missouri
Cranky water heater.
Just got back from a trip to Dallas to spend Thanksgiving with our daughter and new grandson.
The water heater in our 2000 Safari worked fine for about 4 days and then it started acting up. It would fire up and run for about 20 or 30 min and then lock out. It would not start up again until everything cooled down. Then it would run again for about 20 min.
Another symptom is that the pressure relief valve dribbles even after opening and running the hot side of a faucet to relieve pressure.
The water heater on our previous trailer was unreliable also.
Any suggestions before I get an electric heater element?
Bill Howell
Wappapello, Mo.
2000 Safari 27
2005 Dodge Ram 2500 Diesel
WBCCI #2526
wyhjr is offline   Reply With Quote
Old 12-02-2002, 09:15 AM   #2
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
It sounds like the thermostat is not working and it is overheating the water. This could be why the relief valve is "leaking", and the unit is shutting down, until cool. Does the hot water seem REALLY hot? Does the unit have electronic controls, or is it a standard pilot ignition type water heater?
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 12-02-2002, 10:59 AM   #3
2000 27' Safari
Yes, the water does seem pretty HOT!
As far as your other question, the unit is a standard unit with electronic ignition(no pilot light).
Thanks for any suggestions.
Bill Howell
Wappapello, Mo.
2000 Safari 27
WBCCI #2526
Old 12-02-2002, 05:34 PM   #4
gwsullivan's Avatar
I had the same problem with mine. I replaced the pressure relief valve and that solved the problem. I think Atwood used the cheapest valve they could find.
Jerry Sullivan
'01 Limited
'01 Safari
On The Road, USA
gwsullivan is offline   Reply With Quote
Old 12-02-2002, 06:48 PM   #5
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
air
sounds like you have no air space in your tank.
check your owners manual. it should show what i am talking about. there needs to be air in the tank to keep the t and p valve from leaking.
all you do to fix it is drain the tank thru the lower plug and refill.
john
Old 12-02-2002, 09:01 PM   #6
Chas's Avatar
Images: 22
This may seem to be a dumb one but make sure the water heater bypass valve is set right.
It has happened to the best of us!!
Former Airstreamer
Chas is offline   Reply With Quote
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Water heater and furnace need work? goodgrey Water Heaters, Filters & Pumps 18 04-15-2006 10:29 AM
Water leak from either hotwater heater or toilet JLD Plumbing - Systems & Fixtures 7 12-02-2003 05:37 PM
Water Heater Advice! John Sims Water Heaters, Filters & Pumps 1 06-16-2003 08:43 PM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 07:26 AM
