Old 11-11-2015, 09:33 AM   #1
1969 23' Safari
Calgary , Alberta
Copper pipe from water heater - strange size? 69 safari
Hello Airstreamers -
I cut the cooper water pipe about 12 inches out of the water heater in order to replace with PEX. Turns out the copper pipe at this point is not 1/2 inch but is larger - maybe 1/2 inch inside? Does anybody know what this size of copper pipe is and how I might get a fitting onto it to connect it to 1/2 inch copper or PEX?
My airstream is a 69 Safari - any thought or knowledge would be most welcome - thank you
Dave
69airstream is offline   Reply With Quote
Old 11-11-2015, 09:59 AM   #2
1994 34' Excella
Warren , Manitoba
It has been frozen and expanded, but not broken. Had the same problem when replacing copper lines in my 1976. Replace right from the closest point on the heater as possible. If it is the original HWT on the trailer, I would replace it at the same time. Easier to do all the work at the same time!! Good luck, Chris
WBCCI #7394
2002 Chev 2500 HD Duramax
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 11-11-2015, 10:10 AM   #3
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Ditto
I had the same problem on my 64 Bambi. Started replacing pipes one at a time and ended up doing them all. Would have been smarter to rip out all the copper and replace all with PEX.
BambiTex is offline   Reply With Quote
Old 11-11-2015, 12:38 PM   #4
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
1968 20' Globetrotter
ANN ARBOR , THE GREAT LAKES
" Would have been smarter to rip out all the copper and replace all with PEX."
Words of Wisdom...
ALUMINUMINUM is offline   Reply With Quote
Old 11-11-2015, 12:57 PM   #5
1972 27' Overlander
Woodburn , Oregon
I took out all the copper pipes front to back and replaced with pex no more worries for me about broken frozen pipes , very easy stuff to work with so do it right the first time
shineybullet is offline   Reply With Quote
Old 11-11-2015, 01:10 PM   #6
Kevin245's Avatar
As others have indicated, most likely expanded copper line diameter due to freezing water. I suggest making the switch to pex too. The money from selling the scrape copper will go along way towards buying pex tools and materials.
Eleanor Roosevelt
Old 11-11-2015, 01:50 PM   #7
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
True
I think I got $80 for my copper.
Old 11-12-2015, 10:11 AM   #8
1969 23' Safari
Calgary , Alberta
Thanks to all the great posts - I will act on the above - maybe it is best to replace all with PEX - cannot believe how much copper is worth these days. If I pull out the water heater at the same time, what is there a standard replacement heater out there?
Thanks All -
Dave
69 Airstream
Old 11-12-2015, 10:18 AM   #9
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Atwood water heater should fit.
Old 11-12-2015, 10:32 AM   #10
kdickinson's Avatar
1969 23' Safari
Palmer Lake , Colorado
We have a 69 Safari also. All copper water supply is now gone and replaced with PEC. I looked at the copper after it was taken out (I did not do the work myself) and like CBWELL says it had clearly been deformed front to back by age and by freezing & thawing (even though my Dad had it winterized every year) over the past nearly 50 years. The early trailers that had copper seem to have been literally built by hand and the copper was shaped and brazed for each trailer. If you have an AC you likely also have copper installed for a portion of the condensate drain however mine is fine as it is now and would not be subject to freezing unless it was blocked. I would be surprised if your water heater is the original but we replaced the water heater at the same time we did the Pec. It wasn't cheap but well worth it.
kdickinson is offline   Reply With Quote
Old 11-12-2015, 10:41 AM   #11
1977 31' Sovereign
Lynnwood , Washington
It's probably 5/8" copper tubing (replace with type L). Copper tubing has different dimensions than copper pipe. Also, the size 5/8" doesn't exist in copper pipe.
Tom
TomKirk is offline   Reply With Quote
Old 11-12-2015, 11:07 AM   #12
rvb
rvb's Avatar
1977 Argosy 28
Euless , Texas
Many older Airstream's including my '77 have copper refrigeration pipe not plumbing pipe for the water system. I believe it is 1/2" id where plumbing pipe is 1/2" od. You can get fittings and splices at a refrigeration supply company or from an air conditioning repairman. Check around, some wholesale suppliers will sell to the public.
rvb is offline   Reply With Quote
Old 11-12-2015, 02:30 PM   #13
Mission , Texas
The fresh water 1/2 copper on our 75 was a disaster - to include swollen from freezing and impossible to repair. $500 and a couple of days later all fresh water plumbing, pressure regulator and faucets were replaced with PEX, a new regulator and new faucets.
After years of working with other plumbing, PEX is scary simple.
Copper tubing size info here:
https://en.m.wikipedia.org/wiki/Copper_tubing
nrgtrakr is offline   Reply With Quote
Old 11-12-2015, 04:50 PM   #14
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
Hey...Welcome to the 69' Safari club :-)
Yup exactly the same thing in mine, for exactly the same reason everyone says above. Freezing Expansion. Your life will be much easier to just make the break and convert over to pex.
If you have any Safari questions let me know
and here is a link to a printable 69 service manual
http://www.airforums.com/forums/f420...nk-143265.html
thesignlady is offline   Reply With Quote
Copper Pipe Size? jr3149 LP Gas, Piping, Tanks & Regulators 16 01-27-2016 10:32 AM
Copper pipe and pex aren't the same size Loripep 1970 - 1973 Sovereign 7 07-18-2014 11:10 AM
Copper pipe size CBWELL Fresh Water Systems 10 09-07-2009 08:46 PM
Copper Pipe Size Larry71 Fresh Water Systems 5 05-20-2009 09:36 PM
1950s copper pipe connections ivesterm Plumbing - Systems & Fixtures 9 10-02-2003 05:58 AM
