Old 11-12-2015, 05:58 PM   #15
mandolindave's Avatar
Originally Posted by shineybullet View Post
I took out all the copper pipes front to back and replaced with pex no more worries for me about broken frozen pipes , very easy stuff to work with so do it right the first time
I don't see pex as totally worry free. First off, I think that there is a finite amount of times that it can freeze and thaw, before it loses it's elasticity or memory to return to normal shape. Secondly, a chain is only as strong as it's weakest link. The weak link being the elbows and couplers, which I can say, are a pain to remove when replacing.
My point is, I still do the best winterizing job that I can
mandolindave is offline   Reply With Quote
Old 11-12-2015, 07:17 PM   #16
Mission , Texas
Copper pipe from water heater - strange size? 69 safari
PEX does not negate the need to winterize.
nrgtrakr is offline   Reply With Quote
Copper Pipe Size? jr3149 LP Gas, Piping, Tanks & Regulators 16 01-27-2016 10:32 AM
Copper pipe and pex aren't the same size Loripep 1970 - 1973 Sovereign 7 07-18-2014 11:10 AM
Copper pipe size CBWELL Fresh Water Systems 10 09-07-2009 08:46 PM
Copper Pipe Size Larry71 Fresh Water Systems 5 05-20-2009 09:36 PM
1950s copper pipe connections ivesterm Plumbing - Systems & Fixtures 9 10-02-2003 05:58 AM
