10-26-2007, 12:26 PM
1964 22' Safari
Foresthill
Converting water heater pilot to DSI
Is it possible to retrofit water heater pilot light assembly with a DSI (direct spark ignition) similar to what my new Suburban furnace & Dometic fridge have? If so where would I acquire needed parts?
I have a 3 year old Atwood water heater. Works great on LPG or electric, but requires exterior cover to be removed and pilot lit (all of 2.3 minutes) each time I stop to camp for the night.
You're right, Pilot lights are Sooo yesterday
Anyone want my "working" '64 Bowen before it gets hauled to the dump?
Walter
10-26-2007, 02:39 PM
1971 27' Overlander
Central
, Ohio
It would be less expensive to just buy a new one. The ignition control board alone is $190.00.
10-26-2007, 03:02 PM
1964 22' Safari
Foresthill
Thanks, Thats exactly what I wanted to know. I can afford the 2.3 minutes to light the pilot more and will spend my $$$ on others goodies like solar and AGM batteries.
When the Atwood gives out (if it does) I'll go electronic.
thanks
10-26-2007, 03:06 PM
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
From what trailer model? I may be interested in the vent/cover parts that go on the exterior...
Shari
10-26-2007, 04:08 PM
1964 22' Safari
Foresthill
Hey Shari,
It' a stock Bowen from a '64 Safari. Works fine as far as I know. I replaced it only because a new Atwood "fell off a truck" in my lap when I bought the trailer.
Sorry, I was able to rework and retrofit the exterior cover so it looks "original".
The water heater, tank, thermocouple, etc are still here.
Also have original Suburban furnace (again less exterior exhaust cover panel), most of a spare Therm'x catalytic heater, 30# steel propane tanks with old style valves, a fridge from a '64 Bambi, and various '70s Magic Chef stove/oven parts.
Wife wants her car in the garage before it snows this year.
I hate to trash AS parts, I give parts away, I don't do ebay.
Walter
10-26-2007, 05:07 PM
1964 24' Tradewind
dousman
, Wisconsin
Hi Walter,
I am going to be replacing the ( broken ) Bowen water heater in my 64 Tradewind. A PO didn't winterize and lost the lower portion of the cover. I saw a post a while ago on fabricating a new cover to look like the original... so, I am going to give that a try.
What I am interested in is your retro fit process of the Bowen original 2 piece cover on a new unit.
Any Tip?? Photos??
Thanks.
Karol
10-27-2007, 05:15 AM
1973 Argosy 26
Norristown
, Pennsylvania
Shari
Hi Shari; I have brand new unsused outside cover from Attwood 6 gal which I will not be using. You are welcome to it, if you can use it. "Boatdoc"
10-27-2007, 06:22 AM
1990 34' Excella
Parsonsfield,
, Maine
Ganglin is right on. In addition to the DSI electronic module you also would need the electrically operated gas valve and a new gas jet assembly with the electrode assembly. Probably the total of all parts would exceede the cost of a DSI unit new. Check out prices of DSI units at Vintage Airstream Supply. Charlie
10-29-2007, 01:00 AM
1964 22' Safari
Foresthill
i'll get photos of how I installed Bowin cover on the Atwood, when i get home later this week.
Flying around Yosemite and national forests looking for insect damaged trees all week. Someone has to do it!
11-30-2007, 08:54 PM
1951 21' Flying Cloud
1960 24' Tradewind
Folsom
hi, still interested in, looking forward to seeing the photos of your atwood hidden behind the bowen . . .
thanks, mark
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
