Old 07-05-2005, 09:05 PM   #1
1963 19' Globetrotter
Moline , Illinois
Converting pressurized water system to demand.. Is tank vent needed
I am planning to convert the pump in my '63 Globetrotter from pressure to demand. The galvanized tank appears good so I plan to use it if possible. To make this work it looks a if I need to vent the tank/system. Any suggestions as to where and how? Also any suggestions on pump brands/models that work well for my limited needs.
63air is offline   Reply With Quote
Old 07-05-2005, 09:11 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Hello fellow 63 owner,
You can use just about any of the readily available demand RV water pumps, plumb it into the tank outlet, and use the existing pressure inlet for a vent. It might be a good idea to elevate the vent inlet a few more inches above the water level to avoid spillage while driving with a full tank. A piece of fine mesh screen will prevent debris from entering your fresh water supply.
Uwe
www.area63productions.com
No Grey Water Tank????? Anna Waste Systems, Tanks & Totes 16 11-17-2002 07:33 PM
Water Tank Pan Craig Fresh Water Systems 7 09-06-2002 08:52 AM
Water tank drain Craig 1978- 1979 Excella 500 8 08-24-2002 09:02 AM
Finding water leaks FrankR Plumbing - Systems & Fixtures 0 06-27-2002 08:36 AM
White water tank cleaning... Andy R Fresh Water Systems 9 05-17-2002 08:14 PM
