Old 01-30-2014, 05:24 PM   #1
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
Convert water heater gas pilot to electric start?
Has anyone researched the possibility of changing the manual gas pilot lighting of the hot water tank to electric spark ignition. Is this possible?
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 01-30-2014, 05:34 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Possible…probably. You would have to get a parts diagram of both units to see if you can cross-install the required igniter board, igniter/thermocouple and a new solenoid controlled gas valve. 12VDC would also have to be provided for the igniter board's operation, as would a control switch.
Cost effective……probably NOT. In your situation, I would get a new DSI water heater (with an electric element also) AND a new 2 year warranty. The parts required for such a project will add up and closely approximate the cost of a new complete unit.
PLUS, if you are not intimately familiar with working with LP gas components and 12VDC, I would strongly recommend against it!
Old 01-31-2014, 08:35 AM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
There are kits out there that use a 9 volt battery. You still have to open the access door to light it. Just don't have to use a BBQ lighter or match.
OK to Leave Water Heater Pilot Lit While Driving? John&Vicki Water Heaters, Filters & Pumps 3 01-29-2014 10:04 AM
Water Heater gas valve repair Orland Dewey LP Gas, Piping, Tanks & Regulators 3 10-15-2011 05:33 PM
Atwood water heater fast cycling Skater Water Heaters, Filters & Pumps 4 07-22-2011 07:02 PM
Sealing around atwood water heater Hueytownalss Water Heaters, Filters & Pumps 1 06-02-2011 10:07 AM
Water Heater Removal Ag'71 Water Heaters, Filters & Pumps 3 02-21-2011 04:53 PM
