Old 02-24-2016, 10:17 AM   #1
Roquefort's Avatar
1975 29' Ambassador
1986 34.5' Airstream 345
Grefrath/ Germany , NRW
Changing T-STAT / ECO on Atwood?
Name:	ImageUploadedByAirstream Forums1456333189.897287.jpg
ID:	257793Click image for larger version
Name:	ImageUploadedByAirstream Forums1456333225.394611.jpg
ID:	257794Click image for larger version
Name:	ImageUploadedByAirstream Forums1456333253.529116.jpg
ID:	257795Click image for larger version
Name:	ImageUploadedByAirstream Forums1456333292.177771.jpg
Hello!
I need some Help with my old Atwood waterheater.
It went out of work often and the redlight in bathroom flashed on. (mainly while showering, with shampoo in my head...!) Last time, a member here told me to clean the electrical conections and spray them time by time. this helped a while, the burner went on imediately.
Now we became the same issues again in France!
I tried to tighten the contacts, because they were "lousy", and cracked one on the "T-STAT" (see pictures)
To use it as emergency, i conected the black "T-STAT" wires with a wingnut and waterheater lighted imediately. i switched of manually after a while, to avoid overheating.
We have mainly NO HOOK-UP here in Germany for weekendtrips, so the installed (wonderfull!) CAMCO AC heat element is sensless...!
I have a friend in TX, he can ship the new set easily to me, but will this solve my problem???
Heater is allmost 30 years old, i can't get a new one here in Germany. While driving Bangles from IA to the port of Baltimore, they sold us at "Airstream-Ohio" the wrong one...😡😡😡! (no inlet for engine support!)
I am very satisfied with it normally, capacity is sufficient, heat's up quick.
It looks old and rusty, this was the result if an old and bad drain nut. (replaced now with AC heat element, no more leaks!)
WHAT does "ECO" and "T-STAT" exactly do????
Any "tricky" , but "safe" ideas???
Is it a challenge to change the "T-STAT"? Can i try to braze/solder a new wire on it, to re-conect the black wires?
Thank you for a reply!!!!
Roquefort is offline   Reply With Quote
Ram Eco diesel vs. F-150 3.5 Eco-boost Vagante Towing, Tow Vehicles & Hitches 43 06-25-2015 03:16 PM
Signal-stat 3101 Keyholeren Electrical - Systems, Generators, Batteries & Solar 18 07-15-2009 06:39 AM
Signal Stat 9007 driftwood Electrical - Systems, Generators, Batteries & Solar 6 10-06-2003 06:57 PM
M52 fridge t-stat won't react Jabba Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-15-2003 06:57 AM
