Old 02-05-2007, 01:49 PM   #1
kaffe_1477's Avatar
1963 16' Bambi
Metairie , Louisiana
Cat Heater in '63 Bambi
I tried to start up the Cat Heater in my 1963 Bambi, when I push in the pilot button and place a flame in the pilot hole, every burner lights up. When I let go, it all went out, including the pilot. so I tried it again but this time after it all lit up, I held the pilot button to get the thermocouple heated up and let go and it stayed on but for only a minuet or two. Then it all whet out.
I have no idea who the manufacture is but I do know it is the original, any help would be great.
thanks
"This is grain, which any fool can eat, but for which the Lord intended a more divine means of consumption... Beer!"-Robin Hood, Prince of Thieves, Friar Tuck
kaffe_1477 is offline   Reply With Quote
Old 02-05-2007, 02:23 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
My Cat heater (not original equiptment) is a Therm'x. It has one flame for the pilot light. When it lights it ignites the pad behind it. When I release the button and turn the know to low - med - high, the pilot goes out and the pad stays on. This is the correct operation for my unit.
Richard
Old 02-05-2007, 03:08 PM   #3
1968 20' Globetrotter
1955 26' Cruiser Overlander
Bastrop , Texas
I have seen this done, but can't recommend it. "They" say that it could be that the thermocoupler is bad and before you turn on the gas to hold the lighter under it for a few minutes to warm it up. Then turnon the gas and try to start it as usual. The theory being that the thermocoupler is not getting warn emough to stay open.
Jill and Eric
WBCCI #8689
68 Globetrotter
Overlander Underground (Travel and Restoration Blog)
emo59 is offline   Reply With Quote
Old 02-06-2007, 07:55 AM   #4
kaffe_1477's Avatar
1963 16' Bambi
I will try this, but if the thermocoupler is bad the pilot will never stay lit.
Old 02-06-2007, 08:26 AM   #5
2002 25' Safari
Dewey , Arizona
Images: 62
The pilot does not stay lit on my cat heater. It is not supposed to. The pilot is used to ignite the pad. When operational there is no exposed flame.
Does your pad ignite? It should ignite and glow slightly red. After 30 seconds of that, turn the knob to the setting you want and release it pilot button. The pad should stay hot and the pilot flame should go out. The thermocouple you are talking about should be in the pad area.
Richard
1961 - 1963 Bambi Serial Number Guide Andy R 1961 - 1963 Bambi 52 05-08-2018 01:31 PM
Hot water Heater DClark Water Heaters, Filters & Pumps 15 08-25-2017 02:35 AM
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 05:03 AM
