Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 06-26-2010, 10:43 AM   #1
tbettes's Avatar
1960 26' Overlander
1962 16' Bambi
Smithville , Texas
Carbon from Water Heater
After searching this forum I feel lucky my problem is small compared to many. When the water heater lights, the exhaust has some amount of carbon in it, enough to create a trail up the side a few inches after a while. I have tried adjusting the air mix portion of the tube going in but since I am not sure how or what direction to move it, I thought it would be wise to seek the wisdom of the many more experienced people here. How do I adjust the mixture?
Tom
tbettes is offline   Reply With Quote
Old 06-30-2010, 10:44 AM   #2
David Feaster
Escondido , California
Me too
I am also experiencing the carbon buildup and want to join you in asking for information.
--David
feaster@cox. is offline   Reply With Quote
Old 06-30-2010, 11:08 AM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
First check for obstructions, spider web, mud dauber, dirt, in the burner tube and flue.
If you are getting carbon then you need more air, so adjust accordingly.
Old 06-30-2010, 11:18 AM   #4
LEV ZEPPELIN
crazylev's Avatar
2004 19' International CCD
Chicago , Illinois
I just cleaned out a giant nest of something from the burner tube as our WH would not light.
A time before that, we were getting black and smelly soot, also caused by insects residing in gas tube.
After cleaning, all was good.
On our WH there are a whole bunch of screws, some not real easy to get at. Oh, and those screws are not all the same size, so keep track of which hole each screw came from. And on our WH the little metal burner deflector thing at the end of the tube has three holes. Each hole moves the deflector thing away or closer to the end of the tube, so make sure you no which hole that was attached.
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
crazylev is offline   Reply With Quote
Water wood rot under toilet and water heater! Mrcrowley General Interior Topics 4 12-01-2008 02:34 AM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
Water heater & fresh water capacity ESCAPE POD Water Heaters, Filters & Pumps 5 11-14-2007 04:14 PM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
