Old 11-16-2003, 01:00 PM   #1
Cant Find Water Pump!
Greetings,
My new to me 1972 31ft. International is starting to look like a major rehab. Does anyone know where the water pump, and fresh water holding tank are located? Also, I cant find the water pump switch.
Removing the oven shows a water inlet, but no hose attached.
Thanks in advance for any thought and reply.
Dick
Navigator is offline   Reply With Quote
Old 11-16-2003, 01:12 PM   #2
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
The water pump should be under the gally sink area. The water tank under the floor. Look for the freash water filler on the outside this connects direct to water tank.
Garry
Old 11-16-2003, 01:18 PM   #3
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
73 should have the fresh water tank under the floor just in front of the axles. The filler tube should run from the exterior door to the tanks as well as a air vent tube.
The tank sits in a steel box that is bolted to the frame and has a layer of styrofoam insulation between the sides/bottom of the tank and the box. There should be small inspection panel(s) that can be removed to gain access to the tank drain plug. I would check there before dropping the pan. The water pump is normally mounted under the sink on small Aluminum shelf that is mounted to the wall.
The only way to gain access to the top of the tank is going to be the disassembly of the kitchen cabinets. The trailers are assembled as floor on frame, flip it over (wheels up) and install tanks, wiring that is needed and insulate before installing belly pan. Flip it over (wheels down) and install shell and interior.
This is the reason I suggest you check the access panels on the tank pan. Be sure you have a tank first!
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Water Pump David Hall Water Heaters, Filters & Pumps 8 01-12-2004 08:31 PM
Water Pump will not turn on AccessMaster Water Heaters, Filters & Pumps 2 12-07-2003 02:08 PM
Water pump question ipso_facto Water Heaters, Filters & Pumps 12 12-04-2003 12:12 PM
need plumbing map for water pump silverbullet Water Heaters, Filters & Pumps 1 09-22-2002 09:13 PM
Water Pump Dbraw Water Heaters, Filters & Pumps 6 06-15-2002 10:35 AM
