Old 08-13-2003, 07:51 PM   #1
kenlmarc's Avatar
can i get a thermocoupler?
I have a 67 LY with the original water heater but I cant get the piolot light to stay lit. I took the thermocoupler off and checked to see if it was stoped up but I couldn't tell , I could not get a wire to go throug the end that is near the thermo , this is the gas line i'm talking about. If it is not stoped up and the thermo dosn't work can i find a replacement?
'67 31' SLY
Scrapiron's toy
kenlmarc is offline   Reply With Quote
Old 08-13-2003, 09:20 PM   #2
mkeith54's Avatar
1976 26' Argosy 26
New Florence , Missouri
Send a message via AIM to mkeith54 Send a message via Yahoo to mkeith54
ThermoCouple
Hi,
The thermocouple does not carry gas. The end of a thermocouple has a bulb (typically) that has two dissimilar metals that when heated gives off a micro voltage. That voltage holds open a Solenoid that allows gas for the pilot to flow. If when you hold down the button and can light the pilot but it goes out when you releas the gas button then a.) the thermocouple is not centered in the flame or b.) the thermocouple is defective. The thermocouple can be changed if it is bad, any large plumbing shop sould be able to help. If holding the button down does not let out gas to be lit then the gas valve may be bad
Mike Keith
75 Argosy 26'
96 Ford F-250 PowerStroke
mkeith54 is offline   Reply With Quote
reefer repair sjptak Refrigerators 15 08-29-2003 05:00 AM
