Old 09-16-2011, 10:24 PM   #1
Bethany533's Avatar
1983 30' Airstream 300
Covington , Louisiana
Brass fitting into water heater
Does anyone have an opinion about using brass in the plumbing system with an aluminum water heater? My concern is galvanic corrosion.
Bethany533 is offline   Reply With Quote
Old 09-16-2011, 10:30 PM   #2
dznf0g's Avatar
Oswego , Illinois
Well, I'm no expert on the reactivity of various metals...I do remember someone here on the forums is. But I don't THINK that brass vs. aluminum is very corrosive. I do know that my old SOB was 17 years old and I had several brass fittings on a pressure expansion tank system and H2O heater drain valve. Still had the original water heater when I traded for my AS.
Old 09-17-2011, 04:24 AM   #3
richinny's Avatar
2011 34' Classic
read this thread:
http://www.airforums.com/forums/f4/i...num-49955.html
Ricky
Old 09-17-2011, 06:42 AM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
That's how they came from the factory. In our 40 year old Airstream, we have an aluminum tank, brass fittings, and copper pipes.
Old 09-17-2011, 08:37 AM   #5
Kevin245's Avatar
Corrosion is a consideration when joining dissimilar metals. The Anodic Index (AI) lists metals in order of nobility with brass being in the 0.40 to 0.45(V) range, and aluminum (other than 2000 series) coming in around 0.9 to 0.95(V).
The rule of thumb is to keep the AI variance to no more tha 0.25(V) in normal conditions. That being said...brass to aluminum isn't a good combination on paper. In reality though, it is commonly used as Terry indicates.
We have brass fittings in our WH and they work fine. Using an application suitable sealant helps minimize the effect.
We also replaced the drain plug with a thumb value that makes draining the WH much easier.
Atwood water heater drain plug - Airstream Forums
Eleanor Roosevelt
Replacing Water Heater in Argosy 24ft '75 HELP!! eyelashsoup Water Heaters, Filters & Pumps 10 08-23-2011 07:56 PM
Atwood water heater fast cycling Skater Water Heaters, Filters & Pumps 4 07-22-2011 07:02 PM
Water heater won't lite aswbe Water Heaters, Filters & Pumps 6 06-06-2011 09:18 PM
Water Heater Calcium Deposits -- What to do? Wilmington Water Heaters, Filters & Pumps 7 05-18-2011 03:11 PM
